A quickie van project
Starting with a 20p toy!
Hi RonOoh thats a bit wierd. Was it my email addy?
Jim
Jim Smith-Wright
www.p4newstreet.com
www.p4newstreet.com
More progress on the corgi lorries.
Based on comments made over on RMweb here I have lopped a scale 18 inches off the height of the Sunblest one.
Another ongoing project is the Knightwing Volvo tractor unit. It edges nearer to completion.
Jim
Jim Smith-Wright
www.p4newstreet.com
www.p4newstreet.com
I think it could do with about, oh er, a scale 18inches adding on though. It looks a bit short to me :twisted:
Jim
Jim Smith-Wright
www.p4newstreet.com
www.p4newstreet.com
But standards have to be maintained across the board. The same effort needs to go into a delivery van as a class 45.
BTW Chris - Ron has something for you!
Jim
Jim Smith-Wright
www.p4newstreet.com
www.p4newstreet.com
Good point Jim. My regret is the lack of affordable road transport models in the correct scale.But standards have to be maintained across the board. The same effort needs to go into a delivery van as a class 45.
Things are getting better with the likes of Oxford Diecast etc. But the point of this thread is that there are things out there if you know where to look and what to look for. The original Van that started the thread was 20p from a charity toybox. I admit the replacement wheels were a lot more than that!
Heres a before and after shot to show what can be done
Please, anyone else, feel free to post pictures of your own vehicles.
Jim
Last edit: by jim s-w
Jim Smith-Wright
www.p4newstreet.com
www.p4newstreet.com
I've looked and can't find it.
Jim Smith-Wright
www.p4newstreet.com
www.p4newstreet.com
I've given up re-profiling 'Hot Wheels' and the like as a waste of time.
I thought a quick explanation of how I paint wheels might be helpful so
Before we start it's important to understand you must only do one side at a time and that the wheel must be kept horizontal while it dries. As wheels rotate it doesn't look right if they end up with vertical streaks!
1 - start point. Rim colour and black tyre.
2 - paint the wheel with neat thinners. Then use a dark grey to paint round the center of the tyre (not the inside of the tyre). I use Humbrol 67
3 - paint the wheel hub a sludgy brown. (I use Revell 84). I also paint the inside of the tyre with the same colour. By working wet in wet and being sparing with the paint it will all blend together as it dries.
4 - up until now I have been thinking of a normal tyre on a normal road. However it pays to think about what the vehicle does and the effect that will have on the tyres. For my tippler I assumed it spends a fair amount of time in a muddy environment so i have painted a thin ring of pale brown (humbrol 110) around the outside of the wheel. The mud will normally wear off around the outer edge so running a cotton bud around the outside of the tyre will help give this effect. You might want to consider doing the same with white if your layout is set in winter to represent the salt build up you can get.
5 - finally the tyre and wheel may look a bit glossy. A quick spray of matt varnish and you are done.
HTH
Jim
Jim Smith-Wright
www.p4newstreet.com
www.p4newstreet.com
Thanks :thumbs
Been rummaging again and found this!
the white one is from a Knightwing kit and is a tad to big for 4mm scale (being 1;72 scale not 1:76.2) while the red one is another less than a quid Corgi toy. While the cab sits very high and the chassis is rubbish the cab itself is pretty much the same size as the knightwing one if not a tiny bit smaller. Another one for the to do pile!
Jim
Jim Smith-Wright
www.p4newstreet.com
www.p4newstreet.com
As I have been feeling a bit under the weather this week I fancied a simple little project to while away the evening. So having a couple of Base toys trailers lying around I combined the two to make one longer trailer. Extra Details from microstrip except the landing legs which came from a US supplier (Appologies but I cant remember their name)
Jim
Jim Smith-Wright
www.p4newstreet.com
www.p4newstreet.com
Time for another quickie.
EFE Bedford TK, de-liveried with mirrors added and a coating of grime!
Jim
Jim Smith-Wright
www.p4newstreet.com
www.p4newstreet.com
