A quickie van project
(In Topic #3020)
Starting with a 20p toy!
Hi AllInspired by Peters thread over on RMweb here I have picked up (for a massive 20p!) a Corgi Mercedes Minibus. Research shows its pretty accurate for 4mm scale and was in production from the late 60's right up until 1986! It also came in many versions so an ideal candidate for a typical large white van!
Basically (so far) I have cut out the window frames and filled in the side and back windows along with the slot at the back that holds the chassis in place. These infills will need filler and sanding smooth before door lines are scribed on. The wheels have been swapped for Paragon models ones as per my earlier Transit conversions.
Jim
Jim Smith-Wright
www.p4newstreet.com
www.p4newstreet.com
:hmm
cheapskate.. the poor kids!!!
thud:pedal:pedal:cool:
My two are still playing with the one I had - you can still make out the school bus markings on it! I might have to recover it one night now.
Think i call the child protection line :twisted:
Made some more progress on this one.
Where I am stuck is the model has no rear lights and I cant find a piccie of the same. Anyone got any idea's?
Jim
Jim Smith-Wright
www.p4newstreet.com
www.p4newstreet.com
Its a L408 or T2. Turns out the rear lights are mounted in the rear bumper.
My quickie project moves to the nearly there stage!
Glazing is done with a bit of plastic from a Bachmann Mk2 coach box. Interesting stuff as you can bend it quite a lot without it going milky.
A bit more of a fitting environment
Jim
Jim Smith-Wright
www.p4newstreet.com
www.p4newstreet.com
I used Klear Floor polish. If you paint it over the glazing itself it makes it look more glassy somehow!
HTH
Jim
Jim Smith-Wright
www.p4newstreet.com
www.p4newstreet.com
Hmmm frosted windows. That's just given me an idea.
Try coating your accidently frosted windows with clear too - usually gets rid of the frosting.
HTH
Jim
Jim Smith-Wright
www.p4newstreet.com
www.p4newstreet.com
I have grubbied up my mercedes van. Aside from a driver and wing mirrors this one is done :D
Jim
Jim Smith-Wright
www.p4newstreet.com
www.p4newstreet.com
Anyone else?
Jim
Jim Smith-Wright
www.p4newstreet.com
www.p4newstreet.com
MAN cab with Basetoys chassis and flatbed. Hi-Ab from Kibri
Jim
Jim Smith-Wright
www.p4newstreet.com
www.p4newstreet.com
