Cliffs - Using Waste Polystyrene.
I've amended the original link to re direct to This old article
I don't hold out much hope of replacing the photos but I'll add it to the list :roll:
While it is tempting to use tenon saws, the bread knife or the Sunday roast carving knife, don't. They will be blunt beyond redemption after 5 minutes. Use disposable blades (Stanley or similar), even they will be blunt after a few cuts. Hot knives, or hot wires cut and sculpt it easily, and with a bit of practice the foam will look the job. Watch the dust generated while sanding, I run the shop vac while doing it, otherwise the whole house will be covered in tasteful pink or blue dust. Accompanied with the cry of "what have you been doing!".
Make sure the correct adhesive is used. There are special CA glues for styrene foam, as well as caulk type construction adhesive. Closed cell styrene foam will generally take solvent-based spray paint if the original finished surface is there, if not it will be eaten away. Plaster cloth stick well to a sanded surface.
Or you can just get some rock molds and make your own using plaster of Paris. Much heavier though.
a couple of sheets of O gauge stonework wall reinforced with something suitable would fit the bill, suitably shaped and weathered. If my plank or modules were to remain “ portable “ ? light is the key word. Best wishes Kevin
Yes I saw that one. Heating sytrene foam with a naked flame can get quite dangerous. Ijit comes to mind. Hence hot blades and wires. For your purposes some reinforced card with printed weathered bricks or stones glued to it is all that is required. I was actually thinking Lego bricks would do the job. Glue or screw the bases to the board either side of the tracks, make 4 sections of bricks glued together and weather them, drop in place as required, but O scale? Going up in the world?
As for Knives for cutting poly, visit a pound shop, packs of half a dozen very sharp break off knives for ….
