Old mill, old methods and materials.
(In Topic #9600)
If room permits (Admin please advise) I can put up pictures covering the making of the press through to various stages of build but, be warned, there's quite a number of pictures !
Cheers.
Allan.
Last edit: by allan downes
Hi Allan,at this moment in time there is no restriction on photos,i am still waiting to hear about webspace improvements but if you could use the most relevent ones it would help a great deal.
Ok Alan, will do - but it's egg 'n' chips first, just arrived !
Cheers. Allan
BTW Alan, would it be better if I split it into say three posts - stone press mould - construction - finish ?
Why, did Oscar build one too ?!
.So first then, the stone press.
This is made out of plsticine where the stonework is indented into the plasticene with an electricians screw driver, surrounded by a plasticene wall ( pretty colours optional !) then the casting resin mixed as per the instructions, poured into the mould and left for 24 hours to cure.
More to follow.
Allan.
That mold/press looks very handy.
Fire cement do you add anything to it.
It does seem to harden very quickly ?
regards and thanks,
Derek.
Hi Derek.Smashing building Allan.
regards and thanks,
Derek.
Left to air dry it will take quite some time but never go as hard as , a repair compound for fire places should do, where it is subjected to very high temperatures and therefore sets absolutely rock hard.
However, I prepare a wall then put it in the microwave on a low setting for two minutes and it comes out rock hard.
I would suggest, that once you have the stone press made is to cover a 2mm thick ( or 1mm if you prefer) piece of card with the fire cement, sprinkle it over with talc then roll it out even to a constant depth of 2mm.
To do this run two 4mm strips down iether side of the wall then run the roller across these slowly where it will roll out the fire cement to exactly 2mm thick and the talc will stop the fire cement from sticking to the roller.
Next, sprinkle on more powder then press the mould into the soft compound moving it up or along as necessary - it you want even finer stonework still, rubble for example, just keep offsetting the pressings until you are satified with the rersuilts - no two walls need look the same.
Cement pointing.
First colour the stonework with either wood dyes or paint, seal it with a clear coat of sealant, then mix up a very runny mix of water and fire cement and slowly feed it in between the stone joints from one end with a small brush chasing out the air bubbles before it then leave for a good hour to dry right out - but, experimant first and familiarise yourself with the materials and methods.
Any more questions, just fire away.
Cheers.
Allan.
David
Cheers.
Allan
Those latest photo,s are excellent. The stone work is as good as the real thing.
regards,
Derek.
Must think of something similar in N!
Regards, Peter.
Each can do but little, BUT if each did that little all would be done!
So, more on construction tomorrow.
Cheers.
Allan.
Since the wheel wouldn't be turning, I gave it a false bottom so as to locate it firmly at the bottom of the Mill race which would be hidden from view when finished.
Here is an attempt at producing stone tiles although I haven't stuck true to the prototypical practice of laying them in diminishing rows.
So, here I cut out larger tiles than usual - 7mmx7mm - from postcard then laid them individualy.
After, I heaped up a generous ammount of pollyfila powder over the tiles then stippled the powder with an old one inch paint brush loaded with Colron English Light Oak Wood Dye until I had achieved a rough texture that was sealed in with a watery mix of PVA and when dry, dustcoated with aerosol Matt Black up and under the tile edges - just one or two light passes will do.
Anyway, below are the results, see what you think.
Cheers.
Allan.
Amazing
Two kinds of material here, first "RUST-OLEUM" TEXTURED STONE PAINT from B&Q
This spurts three different colours out of the can all at once - how!!!! - and the first picture shows it scribed to look like pavers, while the second shows it 'as is 'straight out of the can.
However, I settled for the fire cement slabs instead - bottom two pics - where a 2mm layer was spread evenly over a sheet of thin card, a piece of broken concrete pressed randomly into the surface to give some kind of relief and texture, then baked i in the microwave for a couple of minutes.
Allan
I can see fire cement sales on the increase.
Plus the stuff does not cost much.
Derek.
The slabs look very convincing. Like old flag stone. Another winner.
