Where are My Topics?
#287401 (In Topic #21605)
My Topics button shows all of Ed's topics!
When I click on the 'My Topics' button, I only see a page of topics created by Ed of this forum!  Should the button be re-named 'Ed's Topics? :P
Breaker of Things
breakage is in the usergroup ‘Administrators’
Hi Terry
It does seem like Ed has some magical power when it comes to that button - is that via PC or Mobile? I'm going to need to set aside some time to investigate that feature.
Hello Jay.  I'm using my PC.
Thanks,
Interesting, I now get Terry's topics when clicking 'my topics'.
Will you two just cut it out ! Swapping your topics round whilly nilly ! My head hurts ☺️
Yeah tiz weird  ? I only get My own topics, well up to now I do ! Now watch it go booblies up 😜
Breaker of Things
Mine's working correctly now  :thumbs:
Intriguing! Let me know if it gets out of whack again.
I'm still getting Ed's!  Maybe I should move in with him!
Try using this form that Martin Wynne kindly set up Terry.
Just put you user id in the Author/Submitter field, scroll down and click 'search content'.
 Search content – Your Model Railway
Breaker of Things
Also worth noting there's a search button in the top right in case you lose that link at anytime - just type your username and hit search and you will get to that form.
Martin Wynne is in the usergroup ‘Super-moderators’
breakage
Hi Jay,
I did tell you what the problem is several weeks ago.
The URL contains the parameter
Code
author=
It takes the USER NAME in text:
Code
author=Martin+Wynne
Then it works fine.
Your URL has the user ID instead of the name. In my case it comes up as author=160 – which gives me Ed's topics.
cheers,
Martin.
Breaker of Things
Martin Wynne said
breakage
Hi Jay,
Code
author=
Code
author=Martin+Wynne
Then it works fine.
cheers,
Martin.
You did, unfortunately that's not how this case works, the link is being generated using system parameters using the cms built in variables, there is a variable called member I'd which is being passed into the link and is not passing the correct value. User name is not a unique value in the DB and can be changed hence user ID number is the unique value.
The issue is that at some point the variable is picking up the wrong ID, I suspect its because that variable is at times used for doing searches or viewing someone else's profile and isn't guaranteed to always hold "logged on  user"
I just haven't had the time to hunt down the correct paramter for current logged in user.
Breaker of Things
I've made some changes, let me know if that fixes it.
Hi,
I have just tried 'My Topics' and got approx. 17 topics from Breakage, who had written the previous tropic, which I had looked at.
Breaker of Things
Claus Ellef said
Hi,
Thanks, I was worried that would be the case. I'll keep looking into it.
Apologies Jay.
Martin.
Breaker of Things
Can you guys please try this out again and let me know if it behaves any better?
Breaker of Things
Jay breakage Just selected my topics and got Alans spurno
Okay, I think I'm going to just have to ditch that button and implement a shot cut search instead.
I'll add it to the list.
Mr no idea here. Martin's method uses The user name. Your working with the user ID number because that won't change even if their  user name gets changed but at the moment gremlins are stopping it working properly. Is Martin's method using the user name giving more consistent results ? Or are BOTH giving random results. If using user name IS giving correct results, Is it worth going with THAT method  for now ? Until you get a chance to work on getting consistent  results using ID number ?  I know this would cause an issue if a user name gets changed, but that doesn't  happen very often tbh and we would be aware of the issue if it DOES happen ? It's more likely a NEW member who needs a user name change, and tbh they would have started very few topics anyway.
Am I talking complete spherical dangly bits ?
