The art of compromise.
A lovely portrayal of horsepower Terry, complete with the recycling crew and equipment waiting patiently.Bill
As stated earlier I have extended the small piece of scenery in the fiddle yard to give the impression that the scenery carries on into the distance when viewed under the bridge from the scenic section. The new extension is to the right of the platelayer's hut. More ballast was added to a farther section of track and awaits painting.
This is the impression when viewed from the scenic section of the layout…
Two Royal Mail bags have been added to the platform. Courtesy of Dart Castings…
And further detailing has taken place between the tracks in the goods yard…
More coal has been scattered around the yard and secured in place with a spray of Testors Dullcote matt varnish. The wheelbarrow has had a coal load added and a shovel thrown onto the coal pile…
I have given up on buying those overpriced track cleaning rubbers which usually deteriorate and shed rubber everywhere. For some time I have been using those dark grey foam sanding blocks which were appropriated from a well known £1 Emporium in packs of three. They work well but are rather too wide to clean OO track, usually taking some surrounding vegetation with them and being impossible to pass under the bridge on Farleigh. The obvious answer is, I suppose, to cut one in half lengthways, although I must admit that it never occurred to me until my wife suggested it! Behind every great man there's a woman, etc. Unfortunately the £1 Emporium no longer sells everything for £1 and has also given up on selling those sanding blocks.
Anyway, said wife was having a tidy up in her crafting shed the other day and asked if this was any good to me…
I have found a UK supplier on the internet who sells similar blocks for £3.49 + postage, for a pack of ten. Each block measures 9.2cm long by 2.5cm on all sides.
https://www.craftydevilspapercraft.co.uk/crafty-devils-sanding-blocks-pack-of-10-white.ir
Other suppliers must be available both inside and outside of the UK. You need to track down (pun intended) suppliers of items for crafting, a hobby usually favoured by the ladies.
Last edit: by col.stephens
Scenic fiddle yard - great stuff. I shall be doing the same.
Not so sure about the abrasive block grit though. Unless it's about #600 or more is will leave scratches that accumulate crud, and reduce traction (not usually an issue for most of us). Snow Blocks are #400 grit equivalent.
Don't worry about the sanding blocks. When I wear the rail down to the chairs, I'll scrap the layout! :lol:
You have modelled a lovely looking station, with some superb green locos to match it. I will look through the entire thread later.
Dave C
The transport police ought to move that guy on from the bench - he's been there ages ..............
