The art of compromise.
Hi Terry. There was an episode with me and Fleabay, and to this day I have many brakevans, four of which are the Queen mother type , Admittedly each with a different livery. Best wishes Kevin
The superb detail belies the small size of this van. It screams out for one of the Modelu guards looking at his watch or just leaning on the end panel.
Hello Kevin. I think you mean 'Queen Mary'. I bought one of these from 'the bay' in SR livery. I'm surprised that Bachmann are getting away with still selling them for the current ridiculous price. Basically an old model and quite crude compared to today's models. No glazing, moulded handrails and old style wide couplings. However, it has a certain charm. I am currently upgrading my model with glazing, corrected paint livery to the cabin partitions and verandah roof, and smaller couplings. I have decided to live with the moulded handrails as it would be a pain trying to remove them all without damaging the sides of the vehicle. It is much too large for any train on Farleigh but it might make an occasional guest appearance when the usual branch brake van is in for repair and they are scratching around for a temporary replacement.
Last edit: by col.stephens
Here is the gauge in operation…
I suspect, when they designed their couplings, they didn't consider my track laying which can occasionally, be ever so slightly less than level which rather negates the necessity of having accurate coupling heights………………… :oops: :shock: :It's a no no
New arrival at Farleigh. Bought this week from the model shop at Seaside, Eastbourne. The weathering on this Dapol model is a bit too red for my liking. After taking the photo I gave it a blast of Humbrol Dark Brown 29 to tone it down a bit. This colour is sold as acrylic paint in a spray can, which I find useful for wafting over the rolling stock to give them a weathered look.
Another new arrival at Farleigh is this beast…
As this vehicle was intended for express goods trains, I doubt it would ever have been seen at a small country station like Farleigh. However, occasionally the branch brake van will be in for repair and on those occasions, as this will be the only available brake van some yard foreman will have it attached to the Farleigh pick-up goods. Failing that excuse, Rule 1 will apply - it's my layout and I'll run what I want!
This is the Bachmann model, so ancient it is believed to have been found in the tomb of Tutankhamun! I bought this Southern Railway liveried example from ebay for around £20. The model, as bought, was quite basic with wide tension-lock couplings, no glazing and the verandahs painted totally in dark brown, which is incorrect for this vehicle. The verandah floors were just the black painted top surface of the metal weight with no attempt at floorboards.
The first job was to dismantle the model. Quite easy as the body clips onto the chassis and the bogies and weight are attached with screws. The top half of the partition ends of the guard's accommodation should be painted Venetian Red. I used Precision Paints product for this and also overpainted the Bachmann red on the verandah ends and headstocks to match the colour throughout. The ceilings of the verandahs were painted white. I glazed all windows, including the duckets, with clear plastic retrieved from discarded packaging. I'm doing my bit to save the planet! I scribed and painted some 20 thou styrene sheet and superglued two pieces to the top of the metal weight to represent the planked flooring in the open verandahs. The footboards were painted to match the verandah flooring and superglued to the bogies. The stovepipe chimney was given a lick of black paint and the lower part of the model was sprayed with Humbrol acrylic Dark Brown 29. Some weathering powders were brushed onto the roof and end platforms to finish. I decided not to replace the moulded handrails as they don't look too bad and I didn't fancy the idea of trying to carve off all of the handrails whilst trying not to remove all of the moulded bolt heads.
The original large couplings were part of the bogie moulding. I cut them off and hacked about two Parkside Dundas NEM coupling mounting blocks (now sold by Peco). These were superglued in place just inside the bogie ends and Bachmann couplings fitted using my home-made height gauge as mentioned previously.
Overall, I am pleased with the improvement to the original model.
What did hit me about the photos was how obtrusive those TL couplings look - almost enough to turn anyone to Kadees…… :cool:
I'm sorry because I'm sure the camera angle has a lot to do with that - what lens are you using and how close to the vans were you ? Both shots have a pronounced perspective …..
Apart from that both wagons look the part - well weathered and will fit in well on the layout. :thumbs
These beauties arrived this morning, courtesy of Tim at Arcadia Models, Oldham.
Ok, not strictly accurate for a branch line set somewhere in the South-East of England.
"I couldn't help myself M'Lud. I was led astray and throw myself on the mercy of the Court!"
Sentenced to 150 hours Community Service i.e. arrive in a mini-bus with a load of other ne'er-do-wells, jump out with your gardening tools, and when the supervisor has disappeared with the bus, sit on a bench and smoke your fags until he reappears four hours later.
"I think I can handle that M'Lud!"
Repentant.
Bill :thumbs
