The art of compromise.
Terry, I think Petermac will want you to do his then you can come to Oz to do mine please... I have a spare bed. ( well I can get one)
Juss woteesed!That is super Terry…. Some painted backscenes try to do too much and end up looking like…. a painted backscene. Your hedges and trees and just enough to give the right impression and you clearly have some skill with a paintbrush because it is very convincing. Looks like a lot of scenes I see from the train window!
D
Total agreement :thumbs[user=1512]Headmaster[/user] wrote:Juss woteesed!That is super Terry…. Some painted backscenes try to do too much and end up looking like…. a painted backscene. Your hedges and trees and just enough to give the right impression and you clearly have some skill with a paintbrush because it is very convincing. Looks like a lot of scenes I see from the train window!
D
Sol , I have booked the flight!
Last edit: by col.stephens
Today, I decided to move things along by adding some trees to the landscape and to enhance the hedgerows. All achieved by dabbing a sap green/black mix onto the canvas with a small hog's hair brush. Plenty of work of this nature left to do so I probably won't be updating this thread for a short while. Here is where we are at present… (please excuse the horizontal lines caused by the shed light
excellent work Terry!
(I'm haunted by the image of a hairbrush belonging to a small hog…)
Thank you all for your kind comments. I am just taking my time and not rushing anything. I want the backscene to be 'in the background' so to speak, with the viewer's attention focused on the modelled scene in front. I am keeping the colours fairly subdued in the hope of achieving this.
You have definitely done that Terry and I think they will set of the models superbly. I think it's really difficult to keep a subtle colour palette, and I know I would be inclined to add too much. Loof forward to seeing them in situ!
I had previously fitted a single strip of 'warm white' LEDs behind the pelmet but became aware that the lighting was a little on the dim side. I recently bought another strip of 'cool white' LEDs for under £10 on the 'bay'. These are much brighter so, in order not to completely swamp the layout in bright light, I stuck these above the original LEDs in small clusters along the length of the layout. It was simplicity itself to run connecting wires from the original LED strip to the new clusters.
I think you are ok with Gesso. Apparently, it is also good for priming mdf before painting. I must investigate it further for possible uses in the model railway arena.
Anyway, back to the goods shed. How to cast a smidgen of light onto the front of the shed? What if I could redirect some of the light coming down from the pelmet? Maybe a small mirror to reflect the light? How would I fix it in position so that it wouldn't be seen? On the rear of a building? The mirror idea was a non-starter simply because of the difficulty in obtaining one so small. In any event, I didn't want a building obscuring the view of the goods shed.
If not a building, what? I needed a small structure which was large enough to hold a small reflective surface of some kind. I was thinking laterally by now and the answer came to me - ballast bin! Would it be possible to make a lineside ballast bin which could hold a small strip of reflective material?
A quick search of the RM Web revealed a thread on 'chippings bins' in which the prototype measurements of a Southern Railway bin were kindly provided. Out came the card and it was a quickly built and given a coat of acrylic paint. And the reflective surface? A strip of very shiny silver plastic from the bag in which the LEDs were packed! Recycle and save the planet!
Here it is…
I cut a small gap in the low embankment at the front of the layout, opposite the goods shed and glued the bin in place. A small amount of ballast was glued at the base of the 'mirror' at the front of the bin. Here is the bin in position looking from the rear of the layout…
And the contents of the goods shed gently lighted. Not brilliantly lit but just enough to see the goods…
More soon.
Just incorporate some smoke now, to go with the mirrors and you'll have earned true wizzard status!
More soon,
