Small layouts planks and micros
Making a mimic panel or unable to
[user=606]Sol[/user] wrote:I've always been a bit of a ditherer Sol ……………….. ;-)OK, Petermac, what is with the flashing LEDs then ? Can't the system makes its mind up?
Max is right - once the point has changed, the new route LED is steady. At first, I thought it was a sort of copy of the crossing barriers which flash alternately whilst they close but I really don't know why they flash. Maybe just to tell me it's moving something, or, just that it looks good ……………… :cheers
My rough plan is using the spare terminals on the switches with a power supply, resistors, and suitable LED's, with either built in sockets on or under the baseboard ( of course they would have to be hidden,from view) but which connectors are best ? I have a plan for the panel , it looks just like your one, only compact .
Please advise. Kevin
I see no reason why you can't use your DPDT switches with an LED wired to them via the resistor. My panel mounted LEDs came with a "normal" wire attached (plain LEDs usually have 2 plain wire "legs" for connections).
Having wires already attached, they could be connected to the "circuit" either by soldering, choc blocks or in fact, any kind of connector you care to use. It's just like connecting any wire to another - do it how you choose to.
Naturally the panel mounted LEDs are more expensive that the plain ones but they are very robust. I'll post a photo of one later so you can see what you're paying for.
I thought of nine different coloured wires and binding them with cable ties, or heat shrink tubing but that may not be satisfactory ? Have you got any good ideas or know where I am able to make such a purchase , as I only require about a yard (or a metre), all the adverts that I have seen quote one hundred metres or more.
All the best. Kevin
For applications like this, I use rainbow cable.
Ribbon cable - Wikipedia
Available at your local electronics store.
It solders well and will easily carry LED current.
I've even used it for CDU's.
If I've stripped them apart, I will usually put a cable tie around them for support.
That's usually enough.
I ask myself. Then I decided it couldn't be my wiring? it must be the extension? Then I inspected the Extension and Lo and Behold it only has 14 pins. I didn't need 15 pins, but wouldn't you know it, one of the pins I chose was the absent one, number 9 as it is present with the original "Male Plug". Maybe I should have stuck with my 5-5-5 plug and socket
Has anyone come across this before?? All the best. Kevin
Best wishes. Kevin
I just went to IKEA and bought a couple of standard lamps and mounted both booms on the one mast.
