Kevin's Inglenook Junction
Two Planks Become One
Ok Kevin but when you connect them does one go through a 180% turn to conect to the other ? Instand reverse wiringAre there points on both boards ? If so do the red and black wires go to the same contact on your DPDT switches ?
I.E. board A red goes to contact 2 black goes to contact 4. . . Board B red goes to contact 2 black to contact 4 ?
Or on one board is it Red 2 Black 4 but the other board Red 4 Black 2 ? Doesn't matter on individual boards but soon as you connect…
I'ts things like this we need to work through slowly to find a cure. Let me know when you have done step one. . Eat the bana. . . No thats step 2 :roll:
I'm trying to figure out what someone has done with the lighting and power wires on an old mainline diesel using multi coloured telephone wires so I have multi coloured spots before me eyes. Red and black is easy peezy !!! :shock:
Cheers Matt
Best wishes Kevin
It doesn't matter two hoots where the bus wires are - front or back - it does matter which rail (on the track) is "black" and which is "red" and that all the connections thereto are the right "colour" and from the corresponding bus.
Hi Petermac. Thank you. In a short while I am going to take some photos of the wiring. Best wishes Kevin
:thumbs
Edit: Forget that, a Banana plug only has one wire :oops:
Then when you turn the boards so B meets A, then of course there will be a short circuit !!
