Kevin's Inglenook Junction
Two Planks Become One
Please excuse my ignorance, as I have not handled this van or so far looked closely at NEM sockets, but what happens if one pulls the fitted tension lock coupling out? Is the NEM socket revealed?Bill quest:
What hooks are you talking about? Do you mean the coupler heads (jaws) come off? Or is it the coupler mounting that fits into the body mounting you're having trouble with?
Last edit: by peterm
HTH
https://www.kadee.com/ho-scale-tools-and-accessories-c-274_282_316/206-ho-insulated-mutipurpose-coupler-height-gauge-p-315.htm
and removing the tension lock is NOT removing something which seems to be perfect. So many varieties !!!
If I wasn't using Kadee, then I would have used the Peco coupling
No 2 if your Printer DOES talk with your Ipad then whats the problem ? I take it you meen your Printer DOESN'T talk to your Ipad.
Is that the case ?, that your printer DOESN'T talk to your Ipad ?
If so then question 1 Why do you want to print ? And What are the prints for ?
If you NEED actual prints you have a couple of options
1) go to a supermarket or shop that has print facilities and get them to print what you want
2) buy a printer that DOES talk to your Ipad
3). On your Ipad open your email client and email YOURSELF a copy of the picture, then open the email on your laptop and use that to print via the printer ( this is dependant on you being able to open your emails on both Ipad and Laptop
If you CAN'T open your email on both then your other option is to upload the photo to your gallery on here from your Ipad and then open that photo from the gallery on your Laptop and print it
Some people like to use photos of the actual stock to be shunted, while others have used playing cards with the photos of the stock stuck on them, which seems a capitol idea!
Good luck and have fun.
:thumbs
