Kevin's Inglenook Junction
Two Planks Become One
When you say tabs Kevin, are we talking browser tabs ? Or do you mean open programm tabs ?
Remember I've mentioned before double press the home button ( little round button ) and it will show you all PROGRAM TABS you have open, swipe left or right to scroll through them and swipe up while hovering over an open program tab to close it. Or tab the open tab to bring it to full screen.
If you don't do this occasionally you end up with loads open in the background
HTH
" Hi Michael. I have been considering the middle ground on my Inglenook, because DAS clay is unlikely to adhere to the plywood baseboard, unless of course there is a medium, glue or whatever , with my cackhandedness I don’t know if the cobblestone sheets would last long and then there the joins to cover up . Have you got any reasonable suggestions that would work with a coal yard? Apart from that keep up the good work. Best wishes Kevin "
Hi Kevin, I'm giving an answer here, where it best belongs, rather than on Michaels's thread. The very easiest and rather appropriate ground finish for a coal yard is quite simply coal dust.
Paint your plywood very dark grey, then spread a thin layer of coal dust over it (Peco do packets of coal dust) and then treat it as you would ballast, i.e. wet it with some water with a trace of washing up liquid, then drop diluted PVA over it with a pipette or similar and leave overnight to set. Job done.
