Kevin's Inglenook Junction
Two Planks Become One
Sorry Kevin , its that time of year again and work is dominating my time atmo. Hopefully it will quiet down to a dull roar later in the year :roll:I agree with Michael, a hint of rock covered partly by undergrouth rather than a full rock face would suffice. You can get fair results using a cheap small bag of tile grout from B&Q or various other outlets. White or cream/ivory for chalk or grey/ brown for other types of rock. Mix the grout in a container to a sticky paste, spread a piece of clingfilm over a spare tile, piece of gass or any flat surface. Use a paint scraper, spatula or old knife to spread the grout out into a semi rough slab to the size you want or roll balls of grout into rocks/ bolders. Leave the grout for a few minutes to start firming up, put a piece of clingfilm over the top and you can then press in some texture to the surface using various tools or a sponge or balled up cloth, even the rough side of a piece of tree bark, anything to get the look you want. You can paint and weather once dry. To make the grout slightly less brittle add a 3_1 pva mix instead of pure water which helps to strenghthen it some. Trial and error with the mix in small amounts until you get what works for you !
Most of all have fun trying !
From Wikipedia. https://en.wikipedia.org/wiki/Southern_England_Chalk_Formation
Edit. Clay is not ground-up chalk. The chlorite group of clays can contain calcium. Usually not from calcium carbonate - chalk.
There are some, but inland cliffs are quite rare in UK. I am of course, excluding man-made ones such as quarry faces etc.
Might make a nice scene. In fact, I might have a go myself!
Last edit: by Headmaster
Ventnor Railway Station, IoW, inland chalk cliff with tunnel.
The yard at Ventnor started almost immediately after exiting the tunnel with a 3-way, then 2 rights and 1 left switch. This was a very small yard, passenger lines in the middle, coal on the right with the offices in caves ("underneath the arches"), goods on the left. No runaround after the platform because of space, a small turntable immediately after the platform was used instead. No cutting was used from the cliff. Signal cabin to the left on exiting the tunnel. Check photos and plans. Plenty on the web. If you want a chalk cliff, no cutting and a small yard this is a good prototype example to base one on. Just takes a bit of imagination and lateral thinking. Plus some graph paper and a pencil and ruler. Doodle, not Google.
You were looking for an example of a railway tunnel through a chalk cliff, no cutting. You now have one.
They pumped me full of antibiotics whilst in there , and have given me more antibiotics in tablet form to bring home.
Best wishes Kevin
