Kevin's Inglenook Junction
Two Planks Become One
PANNIERS? GWR Nutters? Clanking sounds? With Kevin's permission I will return to this later today after a few hymns and prayers and requests for forgiveness.Nigel
Still interested to know what the clanking sound is when the power is removed and it idles as its going along deffo sounds like something ready to fall off.
The clanking you refer to Brian is pent up power just waiting to be released - imagine it as a finely tuned living wonder bursting at the seams on the starting line.
Those horrible things that belch out oil and black pollution need separate heaters to keep the crew warm and are just lumps of dumb iron ………………..they lack any kind of a soul. They're also terrible news for the employment figures…………. …………….
The motion clatter on coasting? Steam engines are not just about chuff. Valves, injectors, vacuum pump ticking, and big ends knocking (especially on preserved models). Plus the gentle simmer of the boiler when at working pressure. DCC sounds are available from various preserved panniers, whether they are representative of the GWR is another matter. I think the 57xx available on ESU decoders comes from at least 3 preserved models.Given the amount of work they do a bit of knock is tolerable.
Whether wearing green, black or maroon, lined or unlined, clean or dirty, pulling freight or passengers, a sight to be admired by aficionados of the steam persuasion. Every layout, whether GWR or of a lesser species, needs a brace (or two). No bias here of course.
The sound decoder i have is a south west digital ESU one on that recording the clanking noise is very prominent as soon as what would be the regulator is shut and the loco is coasting it is related to wheel rotation.
In the week i will see if i can do a little video so you can identify what it is that does the clanking.
One of the benefits of GWR standardization is that any sound file from a small GWR locomotive is fine. I always used the Howes generic one.
Best wishes Kevin. PS any useful suggestions? I thought that it was going too well.
If the Pug is running OK but the Gronk is not then it suggests that it might be the loco. Dirty wheels/pick-ups perhaps? Dirty track can be ruled out by the Pug. I presume that the 08 is happy on all other parts of the layout? If not then its worth checking the loco out.
Its certainly a strange one. It could be DCC related but I know so little about it that I would not like to comment.
If the loco is happy on one plank but not the other then I would suggest that you have an issue with the ol' banana plugs. I use phono leads and sockets from an audio suppliers (was Maplin, now via t'internet) and they work fine although they do require soldered joints. My BBC mate suggests that XLR plugs and sockets are better (as a musician I am very inclined to agree but these are harder to get than phonos and they are much more expensive).
Back at the bananas - Kevin it might be worth checking that the plug connections (screw/solder) are still sound.
Showing a short on DCC but not on DC suggests it's something to do with either the controller or the gronk rather than the plank itself ………………………
When you went off shopping Kevin, did you turn everything off on the layout ?
Check there isn't anything stuck to the gronk wheels - a stray pin, bit of conductive metal or anything else that could cause a short.
Try connecting your DCC controller up to a new bit of track "on the bench" and test the gronk on there - just to make doubly sure it's not "layout" related.
If you connect the controller to the "empty" layout, do you still get the short ? If not, then it's the loco.
Barry - I hadn't thought about using XLR plugs/sockets for links. A useful tip as I have quite a few redundant ones kicking around, as indeed do I have phonos too. And to think, I very nearly threw them out, along with an old mixing desk when we moved - all a symptom of my "hoarding" nature………………..
But OK - connect both boards together, leave the PCP disconnected from the tracks and using the multimeter in Ohms mode( resistance) you can confirm that all tracks are wired & no short circuits.
Unless you have modified CV29 on the gronk to prevent it running on DC, you should be bale to see if the gronk runs on the spare bit of track as PeterMac suggests with just DC.
It all sounds very interesting. From your last paragraph I assume you mean that power to the fiddle yard is through the PCP, power to the scenic part is then through the connectors between the two boards. As long as you have continuity that should not make a scrap of difference.
Now comes the fun part. If you put the 08 on the program track and go into programming mode, does the system recognize the decoder? If not I think you need to open the bag of chips and pop them in the oven.. Because the decoder sounds like it's fried.
If the 08 doesn't run on DC and Cv29 is set to DCC/DC it's a dead parrot. Did it run on DC before? If so it might be the motor or the decoder. Only way to find out is to take it apart and put a DCC blanking plug in. If it runs on DC you have definitely fried the decoder. If not it's the motor and/or wiring. Test the decoder in another locomotive or with a DCC test board.
Now if you left the system on while shopping and it was shorting merrily away you should probably make sure the NCE Power Cab still actually works. I see no mention that you tested it with another chipped locomotive.
Suggested plan of action: Verify Power Cab works. If yes verify that the decoder is still readable. If yes check Cv29. and set to dual mode DCC/DC if it is set on DCC only. Check it runs on DC using a blanking plug. If yes then it's head scratching time. Any no's and "Houston, we have a problem". Oh, and visually inspect the decoder. Is anything melted?
Hi Barry. Thank you for your reply. First things first, I do have a small confession to make, I have fitted the CPC the interface, I think that’s what they call it, on the fiddleyard, whether that makes a difference?
There's an old saying, If it ain't broke, don't fix it!
Your suggestion of moving it back is a good idea Kevin.
Hi Ed, Thank you. Do you mean moving the PCP back to the Inglenook, even though I had suggested that, as it is the socket that is supposed to be alive, and passing the current to the plug, odd? I will do that.Best wishes Kevin[user=1801]Passed Driver[/user] wrote:Hi Barry. Thank you for your reply. First things first, I do have a small confession to make, I have fitted the CPC the interface, I think that’s what they call it, on the fiddleyard, whether that makes a difference?
