Kevin's Inglenook Junction
Two Planks Become One
Woohoo! Kevin has his trains running! Genuinely, only here would there have been so much patience and help. Well done Barry. Now Kevin, lets see some of that scenery develop!
At least you know with Barry helping you everything is as it should be and you had wired it properly you were only i bit overenthusiastic soldering the switch.
With Barry visiting you it sorted it if he had not kindly done that trying to sort it in this thread it could have been a very long time until it was resolved.
Whilst I was over with Kevin the other day I took a couple of photos to show "base camp" as it were - this is the start point. The two "planks" are actually plywood cases with hinged lids and carrying handles. The plywood top easily takes track pins and the lift up lid makes a great backscene. You can see the divider between the two boards - a hinged arrangement that folds neatly into the lid when not in use and adds stability to the lids when opened and engaged on the captive bolt set into the surface of the fiddleyard board.
On the left is the connector for the controller inputs with a nice long lead so this can be mounted where the "banana" pluigs are - between the baseboard joint and the scenic break.
Kevin might be too modest to say but this is a strong base and I am sure that people will continue to support him as he leaps off the top of the scenic cliff (as it were) and starts with the green stuff!!
As an interesting aside, spending 10 minutes driving the "Gronk" up and down with its slow running and range of sounds, honks and hisses made we wonder on the way home whether I could build myself a DCC-sound plank with that bit of spare plywood in the garage…………………
Last edit: by Headmaster
And now the nasty DPDT switch has been sorted you are well on your way i have no doubt there has been a lot of locomotive testing over the last week.
Looks like ballasting next for you Kevin and making some structures.
Barry making a dcc plank is a good idea you can have hours of fun with them and especially with a few small sound locos if your into steam a pannier is a great little sound loco.
As others have said, now the electrics are in order, you can only move one way !! Give your brain a rest and make some buildings or do some scenic work - whilst constantly "testing" your locos of course ………………….
A PANNIER!!! Wash your mouth out Sir!…….
I might actually re-live my youth and model MR/LMS (that is I modelled them when I was young, not that I remember the MR when I was young)
I think Kevin's deep lids will be great for mounting building flats/low-relief as they can remain in place when the lid is closed. They will also allow huts and the like to be fixed to the surface of the board. Taller structures will have to lift off but are easily stored in modern plastic stackable crates.
