DIY N gauge semaphore signals
(In Topic #12589)
Searching for information
Are there any printable N gauge semaphore signals on the web ?It would be useful to source signals, then I could make my own . :pedal
You can try these from (strangely enough, from my own web site) http://xdford.freeasphost.net/stag15.html and
http://xdford.freeasphost.net/stag15b.html
Hope this helps. I use A4 sticker paper for a range of buildings etc and fit the smaller images of the signals in the gaps left over on the page.
You could print multiples on a page. I use Libre Office myself so use the drawing component of it to arrange the images I would use. I have stuck them onto plastic sheet, usually recycled margarine tub lids as a guide and cut them out… Have fun if this works for you!
Edit: You would have to resize these for N scale as well to 0.54 of their current size, but that means you could also use sticker label paper in smaller sizes with less waste
Cheers from Australia
Roy Low
You could use a Darlington power transistor in the place of the two in you circuit.
I used Tip 122 or Tip 127, depending on which sex you need.
roy
Last edit: by Roy Low
