Signal & point levers for manual operation.
#140345 (In Topic #7563)
I recently imported some manual signal/point levers from America to the U.K.  Worked out about £6 per item but much better looking than those thin levers sold by Gem, and not as expensive as the etched brass offerings on the UK market.  Nice product which is moulded  in  plastic and comes complete with tubing and wire.  These definately deserve a wider audience.  Link below:
http://www.humpyard.com/
Terry, those look really good!  Almost makes me want to go away from slow motion motors.  Something to bear in mind.  Bookmarked
Hi Terry            I went on to the net to ask about manual operation of signals and points, to be told" it can't be done", because you break the circuit. But that is my idea, well if it works, you isolate the running rails breaking distance before the danger signal, then throw the points or what ever you want, clear the signal, the train proceeds (Piece of cake) I do watch "You tube" and the amount of layouts that I have seen where an express train goes merrily sailing by a stop signal, as if it was just another telegraph pole, not in my world, S P A D S are out.                                        Passed Driver
They look good Terry, makes me wonder whether I should invest in Seeps or not!!:)
I'd be heart-broken if I couldn't find black Jappaned screws to mount them with….
Hi Terry I have just returned to this thread, and I touched the contact details, but, the first go took me not to Model Railways, but, a different pastime altogether, I came out of that and my second attempt found the correct page.Best wishes Kevin
It's not working for me Terry - but then I noticed it's 7 years ago !!!!
Hello Kevin and Peter.
It appears that the owner has closed down his operation.  Shame, as they were well designed for the task.
Hi Terry.    Thank you for the information, good things never last. Best wishes Kevin
That;s always the risk with cottage industries Terry.  They usually produce excellent stuff - usually from practical experience - but are just kitchen table operations ………………..
I have a box load of Hump Yard bits for evaluation purposes and the quality really is particularly good. Just enough for a wee plank in fact, so not at all wasted.
