Small country station.
(In Topic #12774)
Small station for new micro-layout.
Usually, all my stations look the same so this time I thought I'd try something a little different.Built out of Wills stone sheets - SSMP200 - complemented with Scalelink brass etched windows and plastikard adornments the model took just a week to build.
Here are a few pics.
Allan
I asked Brassmasters if they would consider doing their Scalescenes etched windows in 7mm - the response was that it depends on demand. :hmm
Last edit: by Brossard
Good choice, John. Scalelink, I would say, do a much larger range than anyone else and in all scales too. If you can give me an idea of size and style you need maybe I can help suggest something as I've got the catologue.
Allan
Regards from Oz
Very nice Allan. :thumbs
Are the Wills' sheets difficult to work with being that they are so thick?
Not if you use a REAL knife, Terry, like a Stanley knife that won't shatter like those silly little nancy scapel knives !Very nice Allan. :thumbsAre the Wills' sheets difficult to work with being that they are so thick?Terry
Actually, those Wills sheets at 2mm thick can be cut through a lot easier than most people think. Cutting out window and door apertures from the back only needs a couple of heavy passes with the Stanley knife and they pop out as clean as you like. The instructions on the packet showing several ways of cutting out apertures are an absolute joke !
The sheets can also be bent at a right angles by scoring a deep V groove down the back with a V shaped file. A little solvent brushed down the groove will also help as it softens the plastic.
Allan
There is another alternative (and of course most of us don't have access to large Wills sheets as you do) is to use Slaters or Southeast Finecast embossed sheets. These can be cut very easily since they are only 0.5mm thick, the sheets are quite large too so no futzing about with joins. You mount the embossed sheet on 1mm plastic card. You have to watch out for warping as the solvent used to bond them can do nasty things. I've made a lot of buildings using this method.
I think it's a matter of finding out where your comfort zone lies.
One thing I've noticed with Wills sheets is that over time (a few years) they become brittle.
Hi John.I agree with all you say Allan, especially cutting from the back. A few strokes and you have a score line that snaps cleanly. I use the Olfa knife.
Unfortunately I only have access to the standard size Wills sheets as everyone else does.
I only ever glue the sheets - any plastic sheeting - down over thick (2mm) card. Nothing ever moves and I haven't as yet noticed any turning brittle with time.
Cheers mate.
Allan
Absolutely magnificent work Allan. :thumbs
Oh, I thought I read somewhere, perhaps in one of your articles that you got larger sheets. You are special after all. Ah well. The small size size of Wills sheets is a bit of a disadvantage.Unfortunately I only have access to the standard size Wills sheets as everyone else does.
Allan, another absolute masterpiece.
You’ve sold me on brass etched window frames. No more scratch building ‘em if I can buy them.
Did the finials come from the same supplier?
Evan
We expect no less from Allan, a man whose base standards are so far above mine, he's on Jupiter while I'm in a depression on Earth!!
:mrgreen: :mrgreen: :mrgreen:
:cheers
Marty.
The finials are white metal castings and also supplied by Scalelink.
Allan
I could look at it all day. :doublethumb
Last edit: by amdaley
Regards.
Tony.
Regards.
Tony.
Terrific. Almost tempts me to do a bit of 7mm modeling.
Couldn't agree more about cutters, I use a big beastie with snap-off blades (18mm) for everything. About a tenth of the cost of modeling scalpel blades (which compared to surgical blades are downright blunt).
I noticed this has come up under Computing & The Model Railway > Computer Software. But I think it deserves to be in the scratchbuilding section ? would you like one of our super Mods ( those who work tirelessly in the background for mere pennies ) to move it for you ?
