Scratch building
A claim? Re cost of building your own points
Hi Nigel. Thank you. My ventilatin for soldering is an electric fan, and I sit between the window and the fan.There is a YouTube model, that I have mentioned bafore "Dover Priory", and the close up shots of the track look true to life, if I could build track like that? Then I would be chuffed. My first rush of enthusiasm when I returned to model railways was to build four portable baseboards which are my workbench. I googled a " Cast Iron Flat Surface"but that was too expensive for me. A sheet of plate glass is a good substitute .As for DIY track I will put that idea on a back burner for now. All the best. Kevin
At least you had a look at it and gave it some consideration.
I use a marble floor tile as a level surface for soldering. Past experience with glass is that it doesn't like a hot iron.
