O scale mixed media kitbash/scratchbuild project
(In Topic #12380)
The idea is to use Clevermodels textures for the brickwork, and the roof, which will be sheet metal. The rest will be made from card and wood.
At least, that's the plan!
I'm not sure what industry this could be, though it wont be a rail served structure. The layout is set in 1965 - any suggestions on what it could be would be most appreciated. :)
The idea is that the original garage structure has been built on top of, the roof removed and a new, flat work area with an enclosed staircase up to both it, and the timber and clapboard tower structure.
![](https://c1.staticflickr.com/5/4193/33922227954_864c2d3e43_b.jpg)
I intend to build the structure in the way it would have actually have been built in "reality".
So, the garage structure will take centre stage at the beginning of the build. On top of that, I'll add timber cross beams, and build upwards from there.
I'll post progress photos as and how it goes. :)
Good luck with it. I'll be watching with interest. :cool:
Progress! :D
![](https://c1.staticflickr.com/5/4272/33983985783_2fb68123c5_b.jpg)
![](https://c1.staticflickr.com/5/4221/33983985883_3daf9ed545_b.jpg)
![](https://c1.staticflickr.com/5/4174/34630773222_1ae8d467a9_b.jpg)
![](https://c1.staticflickr.com/5/4180/34630772842_c0575bbeba_b.jpg)
The basic shell is coming together nicely.
The garage itself is made from a core of artists mounting board - great stuff - and wrapped in the Clevermodels kit textures. I'm going to be having the doors/windows closed on the bottom floor, so the white interior won't matter. :)
The rest of the structure is made up of 1/36" basswood strip, and basswood sheet with planks enscribed on one side.
Last edit: by Danielb
![Avatar](https://yourmodelrailway.net//uploads/cns_avatars/1680.jpg)
Robyn
Thanks for the kind comments, Max and Robyn :)
Progress has been slow, granted, but this is as far as I've gotten to date:
![](https://c1.staticflickr.com/5/4213/34988814261_76e5a47963_b.jpg)
![](https://c1.staticflickr.com/5/4248/34988813591_b1538603b4_b.jpg)
![](https://c1.staticflickr.com/5/4255/34733135640_075a82da90_b.jpg)
![](https://c1.staticflickr.com/5/4270/34309565583_7265c23914_b.jpg)
Further progress to come…
Robyn
Still not figured out what the industry will be yet, no. :)
Today I'm going to be building a few boxcar kits, so I'm not sure if I'll get any more progress done on the structure for a little while.
![](https://c1.staticflickr.com/5/4195/34283841384_e280779031_b.jpg)
![](https://c1.staticflickr.com/5/4248/34964036792_3d7a289858_b.jpg)
![](https://c1.staticflickr.com/5/4236/34964035872_ac9ddcc3ee_b.jpg)
![](https://c1.staticflickr.com/5/4262/34283840664_68517d6ab5_b.jpg)
![](https://c1.staticflickr.com/5/4290/34283842164_ffb908345d_b.jpg)
Robyn
I just did an image search of what rafters should look like and went from there.
The doors on the upper floor will be open on the final model, and it will be lit with LED lighting, so you should be able to see inside it when it's on the layout.
The wood is a mix of basswood strips and basswood sheet with a planking effect laser cut into it.
I have no idea who makes it, but I got it from Hobbycraft a long time ago. I don't think they stock it anymore.
Robyn
http://yourmodelrailway.net/view_topic.php?id=14962&forum_id=21
