Francis Levant bogie hopper wagons
(In Topic #11895)
https://www.bing.com...1eo0&ajaxhist=0
So far I've managed to source a number of suitable photos, got a GA drawing (with basic dimensions) and have sketched up some model design ideas. More later, if and when I progress.
G.
Last edit: by Zodiac
In the meantime I've been getting underway with a couple of scratch-built buildings: the SER 'flat iron' offices and the Shipwrights Arms public house next door. Neither are completed but below are a couple of pics showing the stages reached:
Z.
PS, love the avatar
But at least it is scratch-building.
Z.
However, currently I've been thinking through exactly how it will be assembled - it seems that a one piece body cast is probably not doable due to the shape (and large undercuts) so I'm thinking through how to produce the sides and ends and how they will join/go together. And then how it will be mounted on a chassis and how to make that chassis. The design consideration are obviously important for the assembly and completion - get it wrong and I could simply add a huge amount of fettling work to put it together.
G.
As to the final assembly, it occurs to me that a mock up of the body in plastic card would enable you to fairly easily "cut and paste" to finalise the mounting of bogies and underframe.
The chassis will need to be flat a square for the bogie pivot bushes on the underside and able to carry/fit the body on the top side.
G.
Z.
Thanks, and nope. It's a mix of cardboard and plasticard.That's a great looking building. :thumbs Is it all plasticard ?
The floors are 2mm thick card and the rendered walls are thinner smooth card. The brickwork walls are embossed plasticard. Roofs are also card, the pitched ones covered in Redutex slate sheet.
Z.
What glue do you use to stick it all together ? Card, plastic and the "floppy" Redutex sound unlikely bed-fellows ………….:hmm
Card to card - CAA or Roket card glue (thin CAA can also be used to strengthen card edges so that it can be filed and shaped).
Plastic to card - CAA
Redutex is self adhesive and will stick to any flat smooth surface like card or styrene sheet. You don't use it on it's own. It is easy to cut and trim. Also it has good relief (the tiles at least) and is pre-coloured so no painting required. Great stuff and highly recommended.
Z.
Now I'll turn my attention to the wagon.
Z.
:thumbs;-):cool:
Owen
web-cam 2.2.74.174:8081
if the lights are off no cam
Excellent! :thumbs
Now to crack on with the wagon and the next building.
Z.
