A clapboard Goods Shed
(In Topic #13751)
Summat different...
Herewith a picture of the first part of the construction of a goods shed, the back story is that it was a GWR adopted site, gone into the BR Western Region era.A new construction method for me to represent the 6" timber frame clad inside and out with timber, in this case S'Scenes TX37 Cream Clapboard. Designing and printing the door and window components has made me admire John Wiffen all the more, each little tweak puts something else out-of-kilter, but even at 6" it doesn't look too bad. [IMHO]
Wasn't it fortuitous that the last job I did before the SDR shutdown was to take down and repair the sliding shed door?
Poop-poop!
Douglas
I'm a bit confused by the sliding door ……………… :roll: Is there an opening behind it or does it close over the adjacent opening - which appears to either have an internal roller shutter or is boarded up with the same clapboard …………… :hmm
Too much Red Laughing Water, peut-être?
I've photographed it leaning up against another element behind, sorry!
D
Could I ask what you used for the rail and fittings?
John,
I usually do a little pencil sketch before I do anything needing a little thought, herewith the one I did for the door assemblies, thin card coloured with a brown Sharpie, black cartridge paper for the rail and brackets rubbed with a typewriter rubber to roughen it slightly, and two 2.5mm circles of same glued together for the 'pulley' wheels. Pritt Stik to attach the homemade texture picture, lightly scribed down the plank lines.[I rubbed over this sketch with watercolour pencils as it didn't look to clear to start with.
On relection this morning, I decided that the proportions were out of kilter, so today made the double doors differently, I'm happier with these, [below] which is a good thing as they will be on the facing side. This time I remembered the little 'stops' on the runner.
Hope this helps, John,
Douglas
Cheers, Peter!
John,
Douglas
So ingenious…..like cutting the lady in half….obvious once you explain how its done!
Black cartridge paper….brilliant.
I hope you are going to put all this in a book
Shed Doors Version II look great
D
No, the doors and windows are from my first scratchbuilt GWR standard 1922 station, modified for my Bear's End station, and now re-coloured for BR(W). If it's of any interest I'll put a photo of each up somewhere, I have them as JPG if anyone is in need of them.
A bit of fun, I wonder if I can do an oil-skin coat to hang behind the door to cover the unexplained hole?
Douglas
Anyway, a mini-tee-hee!
D
Will you be able to see this once the shed is complete ? It would be a huge pity to hide it all ………………….
I do hope you are going to develop the legend of the owner of those Boots
Thank you for your kind remarks.
Peter, I think I have found someting useful to do with the thick foil sleeves around the top of the RLW bottles, that's what the oilskin is made of, touched up with a black marker pen. You're right, the 'wellies' are chopped off Dapol figure legs! You might get to see them if you are 1" high and visit the shed, but, see below….
John, haven't I introduced you to the owner of the boots? That's Stinky Smith, otherwise known as 'Smiff the Whiff'. His greasy cap is on top of the filing cabinet. Since he started to leave his wellies there all the time there hasn't been a single verminous visitor to the Goods Shed. Come to think of it, there are very few of the two legged variety either….They do say his mother was scared by a Wrights Coal Tar Soap rep when she was carrying him.
Poop-poop!
Douglas
