Which ballast
(In Topic #12447)
Happy Modelling
Kev
Kev
I like to mix different colours too since real ballast is not monochrome.
Happy Modelling
Kev
Kev
Been trying to use it up by putting a small amount of medium in with the fine, not that I've done much ballasting recently :oops:
I use N and HO scale granite chips (Noch/Gaugemaster or similar), no issues about lifting/floating when gluing down and easier to tamp between the ties. Cost effective for a small layout, expensive for a big one.
One thing you can do with the organic ballast (walnut shells I think if it's WS) is to give the HO/OO scale one a quick blast in a herb chopper (10-30 seconds, test beforehand, the aim is to be somewhere between HO and N). Also useful for reducing the size of the N scale one for yards or the track side walkways.
Happy Modelling
Kev
Kev
I have heard of some ballasts turning a kind of green colour if pva is used with them but not Woodland Scenics.
Tony.
Regards.
Tony.
Regards.
Tony.
I'm happy with it.
Which now begs the question. Why is all designated ballast overscale ?
As for the colour well, this depends on whether or not that you are modelling a prototype in which case the choice is made for you. However, since I hardly ever model prototypes, then what looks best rules and, in most cases, that means light or dark brown.
Anyway, all ballast when fixed down with PVA ( although I use super thin superglue because it's instant and more agreeable than lakes of PVA that take an eternity to completely dry out ) will darken considerably.
Allan.
Happy Modelling
Kev
Kev
The cheapest supplier by a very large margin is SILVERSIL as stocked by EUROCELL BUILDING PLASTICS ( check on line for a supplier near you )'Super thin superglue' sounds interesting Allan, how do we get hold of some.
They charge £1. 51p for a 50 gram bottle as opposed to model shop prices at £ 8 for the same amount.
Alternatively, try BONDFIX ( bondfix@hotmail.co.uk ) as sold on Ebay although considerably dearer than SILVERSIL it's also considerably cheaper than model shop rip off prices and when ordering, always quote viscosity - ie, thin, super thin, medium, thick. Also SILVERSIL super glue accelerator is £ 1 78p for a 200ml spray can whereas a model shop will gladly and swiftly relieve you of 10 quid for the same.
Hope this helps.
Allan.
Granite is pretty inert stuff, the reason for the green tint (discussed before on this forum) is because of reaction of the mineral or rails (N/S rail is brass) with acetic acid in cheap PVA. Ferrous acetate (granite can contain contain ferric and ferrous oxide, up to 4%) is a tasteful green. As is copper acetate. I've never had this problem with good quality acid-free PVA ("pH neutral") over the last 14 years.I have used green scene ballast . i think it is made from nut shells or similar . the reason is, it does not take on a greenish hue when used with PVA granite will.. oh yes n gauge for OO
I've read that a 3:1 mix of HO/OO and N seems to be best for HO/OO. I use about the same ratio with the granite.
Thanks Allan, going to search around :thumbs[user=1338]Ed[/user] wrote:The cheapest supplier by a very large margin is SILVERSIL as stocked by EUROCELL BUILDING PLASTICS ( check on line for a supplier near you )'Super thin superglue' sounds interesting Allan, how do we get hold of some.
Hope this helps.
Allan.
There are ways to attach ballast without flooding with white glue and getting that rainy-day sheen.
Also, the type of plastic used for trackwork compares to that used for food containers and no way will CA attack that either let alone glue it - and neither will any solvent. In fact, nothing will.
Allan
Last edit: by allan downes
If so, I tried it once which was marketed under the name of 'Magic Ballast' and that was a total and utter failure and an expensive one too.
Allan
