Lift Construction
(In Topic #7469)
Bolts
Hi again-hope I'm not becoming too big a pain in the —- I am now commencing the building of the "glass" passenger lift using plastruct sections for the main structural frame.Question is rather than making all joints appear as "welded" ones I'd like to build it using bolts and haven't a clue how to do that-any help would be greatly appreciated
Thanks again
Ian
hmm
Ian, most certainly not a PITA !!! This club is for asking questions as well as showing your work. It's a world wide reference work for information about qanything to do with model railways. :thumbsHi again-hope I'm not becoming too big a pain in the —- I am now commencing the building of the "glass" passenger lift using plastruct sections for the main structural frame.
Thanks again
Ianhmm
You say you want to use "bolts" - what about rivets instead ?
Is this 4mm scale ? If so, bolt heads would be hard to see in any detail although there would be a "mark" where they are. You can actually buy sheets of styrene "rivets" - I really have no idea how these would be cut out but there you are.
A good system of making rivets is to use a tiny blob of glue as the rounded rivet head and, once everything is assembled, dry brush the rows of rivets to highlight them - works well.
Yet another method - for sheet material is to punch an indent on the reverse side before assembly then dry brush once again.
I have seen bolt heads punched out of card, but not at this scale………….
Here's what I mean made by a modelling friend of mine in UK - all done in card !!! :
I would like to show bolts rather than rivets given the era of the model(80-Noughties).The illustration of your friends work in card, you provided, is absolutely amazing.
I'm looking for say a length of 0.66mm in hex section plastic to cut into 0.5 mm slices.
Don't really know if I'm being unrealistic in my expectations or not!
Thanks again for your kind interest
Ian:Red Card
Thanks for all your help.
Ian
I'm e-mailing him tonight so will see what he says. :roll:
You melt plastic sprue into the mould shapes, then trim.
Stu
I've been meaning to read it from the beginning, but I can't find the start.
I promise I'll delete these posts once somebody points me in the right direction.
I must be like the grave diggers wandering around in the Cemetery.
I've lost the plot. - Again.
I wonder if he's got a layout thread somewhere ………………
Here you go Max :
http://yourmodelrailway.net/view_topic.php?id=9873&forum_id=8
Thanks again
Ian
Kind regards
Ian:hmm
How does that tool work?
Ignore this - I just re-read your last post.
Last edit: by col.stephens
I have used them when buildind wood models.
Ian
Any DCC is better than no DCC
Ian in cold wet England!
