The Viaduct
It looks really 'heavy' and substantial - just the way it should.
Perry
Taken from Charde end.
The next one is at the other end looking towards the point & junction. Right hand track goes to Durston underneath Charde.
3 locos, Dave, that is it- coz I do like those small diesels. I obtained them from my mate who still has 3 plus a load of carriages that Murphys models released.Nice to see a touch of the Irish there Sol… how much Irish rolling stock do you have?
:shock: Nice 142 Sol!!!The top now finished, track to be painted etc but this will have to do for a while. I have a few other modelling things to get started/finished now.
Excellent work on the viaduct
Just read the full thread - Nice one.
As for the flatness of the card, as a test I tried printing on to textured watercolour paper (off cuts from my local art shop) with the stone dock side walls and it made a vast difference, just enough to stop it looking flat.
Paul
[user=95]Sol[/user] wrote:
Pete, I thought this photo ( yes slightly out of focus) will give you the idea of space for double tracks.
I set the tracks with 6ft way between centre rails = 24mm so centre- centre is 40mm & a bit close on each arch side
With some minor effort & time, you could add say another 1/2"/ 12mm in width to the top of the arch .
Cheers for checking Ron it is a bit tight which is a shame, i was sat on a plate girder bridge the other day so plan B, Plate girder spanning the rails and the viaduct arches either side. I need the arches cos one side is having a garage on a street scene not original i know.
Still watching your mini Ribbleshead
:thumbs
Hi Pete,
I realise this is an old thread but, for future reference, to increase the arch width you could print the Scalescenes kit at say 10% oversize which should then give you the extra sideways clearance you need. It would be slightly overscale but not enough to be noticable. Increasing the height of the support pillars would also increase the side clearance.
Nice piece of work Sol. :thumbs
Last edit: by Chinahand
plaster was still wet and now painted a tan colour.
the far end by the tunnel mouth
now with some colour added ( glue still wet !)
bit by bit, this will change to the better hopefully.
That river has to female, with that many changes of direction
Paul
Looking very good though Ron and should be a real feature when finished.
Nice one Ron
Paul
It's looking really good sol. What a difference that bit of green has made. :thumbs
Is the plaster just "plaster" ? It looks a bit like baked meringue with that browny/pinky tinge. Here, plaster would normally be be white. :thumbs
Looking forward to seeing the marsh take shape - a great idea. :thumbs:thumbs
yes Peter, normal white plaster with coloured poster powders added so that if it gets chipped. not so white looking.
then painted with a tan colour and the occasional dark brown wash before adding grass colours, etc
bit more done… purchased a tin of gloss clear paint today to try over the weekend after a lot of "junk, etc" added into the watery areas.
