One of the Freebies
#55810 (In Topic #3078)
Can be downloaded  for free, nothing, no charge, etc.
The industry name is my creation.
That's a good 'un Sol. Could find a place on a lot of layouts.
That looks excellent Sol - and for free it's amazing although I'm sure much of it is in the hands of the builder. :roll::roll::roll:
Before I can use Scalescenes I'll have to buy a new printer.  Mine (a Lexmark X75 all-in-one) makes a real pigs ear of anything like that.  The colours are way out. :twisted::twisted:
Last edit: by Petermac
Peter, over here, we can obtain colour printers which copy & scan for less than the price of a locomotive - some as low as 35-40 quid.
Bob, on my previous layout, Iva Brick & Son fitted in , I had plenty of room for private sidings, etc, in fact my small terminal of Watchit ( this one was just before Iva Brick was built)
I ended up with 8 different places top drop/pick up wagons & with 3 other larger stations, I had many more places. Unfortunately, this new layout, while it has more roundy-roundy running, has less stations, so less places to drop/pickup. Even last night at a "play"session with some friends, it was noted that perhaps I should have not only remained with the previous incarnation but the one before that - East Coast North American & there was someting to be said about time in my hobby life.
Ah well, we live & learn!
 Nice building, Ron, but is it gratis ?
 Can you please tell me exactly what it's printed onto?  Scalescenes mention printing straight onto card. Is that what you did, and where did you get the card, please? No-one around here seems to have anything suitable.
 edit: it's ok  I just read your other Scalescenes thread. Cereal box card eh? I've used that in the past as well, but I hate having to cut things out twice. That's one of the reasons I haven't built much in this way.
Gratis for the file that is downloaded, but it cost us paper ,ink & card, You possibly could print some of it on thin card but most relies on glueing it to card upto 2mm thick. Usually art shops have all thickness of card.
When I was in the UK I bought all my quality card from the local printers.
That's interesting Bob - pretty cheap compared with the local art shop I'd imagine.
Here, I have to drive 2 hours to find a decent source and even then,  the thickness or grade I want isn't in stock !!!
Much cheaper but of course it did come in big sheets, as it does here in Benidorm. If you only need a small amount then an art shop or photographers might be better. The bigger branches of Smith's in the UK also sell card.
Thanks for that   I'll check out those sources
I did experement with thin card with the first signal box I built although I had problems with it getting stuck in the printer!
Another one of the freebies. Built by many I think
All the bits  glued to card & cut out & the paper parts to be wrapped & glued.
It won't be used as a Goods but Railway Stores shed. Now to start putting it together.
I haven't seen one built up on brick walls before Sol, neat.
The internal  & external walls of the ends plus a couple of clad & unclad piers.
Side walls added
Underneath detail which is normally seen
Neat.  :thumbs
Slowly coming together - the ramp is twice as long as the download version
I guess that's the beauty of them.  You can add bits where you want.
Nearly finished
Instead of the panel roofing, I used corrugated iron & also fitted my style of Gutters similar to the Goods Shed I built for Watchit - 2 thin pieces of card glued to make a right angle
Door handle is a Peco track pin cut & shaped.
Downpipes are being made & will be installed when this shed is located at Charde. It will probably take me as long to site the shed & ground terrain as it took to build it.
The other side  will be against the run-around loop to allow odd vans, etc  to unload direct into the railway stores shed.
That looks excellent Sol. :thumbs
Looking at the slope on the ramp, I'd say it needed to be twice the designed length - trying to push a barrow up one half that length might have been a bit difficult …………:roll:
I like the corrugated iron - what is it ?
Peter, Corrugated card in H0 scale actually from an Model manufacturer here in South Oz.  I have sent a photo to Mr Scalescenes, John Wiffen.
