concrete bridge
(In Topic #6909)
The file size is 4mB & to purchase it so you can have as many copies as you like , is £4 & that should not break the bank.
Like everyone else, copyright owners have to make a living and they can't do that if people pass copies of their work around. Would you work for free ? I doubt it.
You can print off anything you find on the net for your own non-commercial use. The problem arises when it comes to publishing or offering a copy of something commercial.
Copyright means just that - the right to make a copy. All Scalescenes downloads are stated to be available for your own use and can be printed off as many times as you like. "For your own use" being the important bit. You pay not only for the print, but also for the "right" to "copy" it whenever you like - it remains on your list of downloads within your computer. Passing those copies on to anyone else breaches the copyright.
I'm pretty sure GC Textures are "freely avaialable" to all comers. As such, there would be no need to "pass them on" as everyone already has free access to them.
In short - you're safe to print them off for your own use.
It's not a difficult thing to model with the right techniques. Why not have a go rather than just printing something out?
Jim
Jim Smith-Wright
www.p4newstreet.com
www.p4newstreet.com
Once the model is ready, the 'concrete' effect is obtained with the use of 'Suede' paint.
I expect he'll be along shortly.
I don't think it's really fair to compare the two - either in terms of the standard of modelling or the cost. Just about anyone can make a reasonably presentable job of a Scalescenes download given a bit of time and care, not many could produce something even close to Jim's bridge.
Sorry but it's just bits of microstrip stuck to a base and sprayed with suede paint. Assuming you can stick 2 things together theres no way you couldn't make something exactly like it. It's a damn site easier than wrapping paper print outs round cardboard I can tell you!
Don't give up before you have had a go.
If suede paint is too expensive or you can't find any blow ground White pepper across wet paint for the same effect
Hth
Jim
Last edit: by jim s-w
Jim Smith-Wright
www.p4newstreet.com
www.p4newstreet.com
Sure - see
You might be right in that it might be steel underneath but the surface is definitely concrete.
Remember when new street was rebuilt concrete was the wonder material of the day, there's masses of it in all shapes and textures!
Jim
Jim Smith-Wright
www.p4newstreet.com
www.p4newstreet.com
Hmm, now there's a good tip. :hmm……………………………………………………..
Hth
Jim
Jim
Jim Smith-Wright
www.p4newstreet.com
www.p4newstreet.com
Instead of masonary paint I used exterior white emulsion mixed with a bit of polyfilla and a bit of PVA to make a sticky coating. Not sure of the proportions - sort of suck it and see (no, don't suck it…)
I coated the cottage pictured below, though it doesn't show too well in the picture, in real life its quite effective as cement render.
HTH
Shaun. (the other one)
