Check your printer .............
Make sure your printer is correctly calibrated
Hi PeterI am so sorry to hear about your printing problem. I know just how long it takes to cut those arches out. It was indeed me that suggested printing everything in one go but this advice was based on the colour variation I experienced on the roof panels……..there was only a few weeks (and not much other printing) between the two printings but the difference in shade was quite marked.
I havent come accross the sizing problem before …..one to remember thank you
……….. however in North America as John said we have an issue in that A4 is not available and we use 8.5 x 11 which is marginally smaller resulting in small portions of some designs not being printed……..the roof Arches being one such case. :roll:One other point…..have you given any thought to the visibiilty of the platforms under the roof………I am not referring to physical lift off access, I believe you have addressed that ……..I was thinking more of the day to day operational aspect. I omitted the glazing and cut back the roofing on two of the panels on the viewing side……
There is probably a more elegant way of doing it but in my case its proved very worthwhile.
You can see the shade variation above…….which is going to be much worse when I do the final panel…..I have a nasty feeling I inadvertently got rid of the roof sheet:oops:
Kind Regards
I think I mentioned elsewhere that I thought your printing problem was more to do with colour shift than sizing. I admit, I've never hit this size problem before - but then maybe this is the first time I've changed the printer mid job …………:roll::roll::roll: I'll know in future to learn from those who've been there before me and remember what they say………..:???:
Regarding operational viewing, as you've hinted at, my idea was to make several of the roof sections (on the viewing side) "plug in". This will involve fitting some cross beams between the main trusses. I still have to work that one out and it may be that it won't come to fruition at all. Your idea of an open roof looks very good - it also lets the smoke and steam out thus keeping the brickwork clean …………….:cheers.
Building this roof is quite an undertaking - hence it's taking me so long ………:oops::oops:
As your new prints are smaller, check to see if you have borders turned off, then try scaling up your current prints to match the old ones. You can worry about the correct size for the next roof :roll:.
Paul
Firstly, the PDF viewer will open large enough to fill your screen, and will then zoom in on the file so it fits as best it can. This will be where your 174% or whatever it is, is coming from. This is just the size you're looking at on the screen and will have no bearing on the printing.
When you press Print and the dialogue screen comes up, there are two places you need to go to check sizing etc.
The first screen is the PDF software. Make sure:
1. "Size" is selected in the "Page Size & Handling" section.
2. "Size Options" is set to "Actual Size" and not "Fit" or "Shrink oversize pages"
3. "Orientation" is "Portrait", not "Landscape" or "Auto portrait/landscape"
4. Click "Page Setup" and check that the size is right for your printer. A4 in your case, which you've checked.
Next, you need to check your printer driver itself, which is probably where your problem comes from. You get to that by pressing the "Properties" button next to the box that shows your printer's name.
In here, I'd suggest:
1. If there is a "borderless" option, tick it. (Or untick it - try experimenting)
2. If there is a "Scale" option, make sure it is 100% and NOT "To fit A4" or similar
3. "Layout" should be "normal" and not "booklet" or anything else
4. Page size should be A4 here too
You've probably tried all of that, but just in case not, I hope this might help someone, somewhere!
It's been mentioned already, but I think most Scalescenes kits have a scale rule on them. If not, you can download one here:
http://www.scalescenes.com/tools/Scale_Ruler.pdf
I'll have a play and obviously learn more about my printer than I knew was possible but, as far as the scaling is concerned, within reason, I don't think it actually matters if it's not accurate, as long as everything is printed to the same (inaccurate) scale. My problem only occurred because I changed printers mid-job. Something to watch out for in future and certainly something to watch out for if one has two printers in use at the same time……………..:roll::roll:
I might do some exprerimenting. I have 2 printers in fact, including those "stored in boxes because the ink cartridges were dearer than the new printer was", probably around 4 or 5. On the other hand, bringing any of them back into use would mean buying new ink cartridges and, as the cost of those was the reason they were returned to their boxes, it's unlikely. It really is a crazy situation when, for around the price of 2 ink cartridges, one can buy a new printer complete with ink !!!
Peter, experience here in Aust tends to indicate the supplied cartridges with some printers are not full of ink.It really is a crazy situation when, for around the price of 2 ink cartridges, one can buy a new printer complete with ink !!!
When they run out, it can cost around 25 to 30 euros per cartridge (my HP takes 2) but the printer itself only cost me 89 euros !!!
For some reason, I've always had problems with cartridges drying out or otherwise clogging after using the printer for around 12 months, not, I hasten to add, still with the original cartridges - both "own brand" and "generics" - so, after having changed them a few times, I tend to look at a new printer because the models change so quickly. My current one - an HP "Envy" - is certainly better than my previous Epson model.
Use a colour Laser. Initial outlay may be a little higher, a set of toner cartridges may cost more but do thousands of pages so cost per page is much much lower than ink jets, especially using refilled toners. Also not essential to varnish, toner is more durable than ink. I've been using one for more than 8 years now.
(I used to repair printers, we had far more Epsons with clogged jets than any other make, HP included jets as part of the cartridge so less of a problem, don't know if that's still the case)
Last edit: by Dorsetmike
Not sure if they post abroad.
I have to thank Mr Wiffen for helping keep my printer jets clean:Happy
Paul
http://www.cartridgepeople.com/
My current printer is an Epson. I have had no problem with the quality of the generic cartridges which you can buy either individually or even cheaper as a set. This supplier has a 'no quibble' exchange policy. I have been very impressed with their service in the past when, on the odd occasion, I have had a problem. I believe they are based in Jersey so I would have thought they might send them to France.
Also, for you US/Canada folks, if you print out on Legal size paper, nothing gets compressed or lost.
Jim F
SECR and LBSCR
1900 - 1910
OO
1900 - 1910
OO
"For your own reference, the standard title box at the base of each of the kit pages should be pretty close to 72.5mm wide"
E fonte et origine…
Doug [Scribe to the Tribe of Wiffen]
Same computer; same driver; same paper stock; same settings as before BUT colours now printing a previously printed T026_TX02.pdf, are quite different. Don't appear to be able to change the colour management settings to adjust this.
Any ideas would be useful! please…
You are right, I could buy a printer for what a set of cartridges cost. Still, they seem to last a good while.
