i think we TC we all have hit a wall at some stage, you are now over that wall and you will find that things come together.
a question for you:lol:
as you are into sound setup on chips can you add any number of wav files to that chip?
my thought behind this is, when a train enters platform one at the end of a schedule you could set up an operation that plays a wav file from the sound loco. such as the train now entering platform 1 is the etc etc. i know you can set TC to operate a file on the PC such as a wav file.
Progress Report:-      I tried to do my Contact Indicators via the Manual - too hard!
Max i have got the t-shirt for that one i was scratching my head for weeks. It was only at the get together we had here in the UK after i was shown did i get it. Matt and BrianPr1 might have heard a muffled expletive from my direction after we were shown. Doing the contact indicators is such a critical step as well
Since then after Matt introduced me to this forum and JD's tute i haven't looked back.
Looking at the piccy Max you are well on the way.
Pete
Pete.
Thanks, Pete.  I'm still not sure what they do, but they are in there.  :shock:
Matt, yes I can add any sound you like.  I recently did a loco with a dog barking for a demo at a clinic I was doing.  The only problem is, you must have Loksound 3.5 decoders to do it.  But it is easily done.  :thumbs
Progress Report:-      I tried to do my Contact Indicators via the Manual - too hard!  Went to John's Tutorial - Maggies Meat!  Easy as; thanks, John.
Snail's pace, I know.  But I'm progressing!  :thumbs
Thats great Max:doublethumb:doublethumb glad it worked out.
Sorry I am so slow replying……I would have wished to be the first to email but we are out on the boat again….. Blue Skies, 15 knot westerly…….its a tough life but someone has to do it :lol:
Once again…………well done:doublethumb:doublethumb
. . . you can go right off some people.
Thanks, John.
Update . . .
All four locos are now displayed in their relevant blocks.  Manually drove a loco from one end of the layout to the other and watched the loco icon move across the page.
Ran a loco automatically (Run with Interlocking).  The pathway seemed to set up randomly - different each time.  I'll have to read up on that.
Much too much deceleration time.  I'll have to read up on that as well.
Progress slow, but steady.  :thumbs
Update . . .
Max this is where you need to create a schedule i.e starting block and finishing block and the route you wish to take. Once the schedule is set up it doesn't matter what loco is in the start block unless you wish to specify that.
De-acceleration is related to speed profiling each loco a topic and exercise in its own right, and the braking distance you set in the block.
It sounds you are getting on well, you must of been pleasantly pleased when you saw the loco slowly stopping on its own max?
Pete
Pete.
Excellent progress Max
I was just about to reply and Pete beat me to it………I have nothing to add, he wrote exactly what I was going to do
I am afraid I am off on the boat again tomorrow and internet access is even more limited where we will be heading……but I will try and keep in touch
Good Luck
Sorry Master, i must have had a good teacher:lol::lol::lol::lol:
Pete.
I'm lucky that I use Loksound decoders and it's easy to change anything in the performance area on the programmer.  I saw that Scheduling is my next job.  I'm not lost, just reporting back.  Cheers.
As you can see, I have assigned each of the locos and the little icon shows which way it's pointing.
I have put them all on the Lokprogrammer and given them 3 seconds braking time which stops them in the right place in the terminus blocks.
As an exercise, I went into Train - Driving - Run with Interlocking - and try as I might, I couldn't get them collide or run over any turnouts set against them.  I even set more than one off at a time, running towards each other, but TC kept them safe.
I'm ready to find out how to do the Schedules.  Watch this space.  :thumbs
Great to see your progress, Max. Just a little caution with your above statement. I don't think the orange and green arrows in the train windows actually do show which way the loco is pointing. Rather they show whether the loco is going to go backwards or forwards, regardless of which direction it is pointed.
In other words, if a loco is pointing from left to right, a green arrow means it is going to go forwards to the right, but if a loco is pointing from right to left, then a green arrow still means it is going to go forwards, but this time, to the left.
Yes Max that is very satisfying watching an engine stop due to the block ahead being occupied then starting up again when its clear smashing!
Keep it going.
Pete
Last edit: by wogga
Pete.
Not the orange and green arrows, Geoff.  In the block where the locos are, there is a small image of the front of the loco which indicates which end is the front of the loco, depending on which end of the block it is.  Hope that makes sense.  :oops:
you can use the TC image software to add you own pictures. take a picture of your loco and have a go. you need to crop the picture you take first.
Thanks, Matt.  I saw that.  It's on my "to do" list.  :lol:
Well.  Well.  I got to Page 55 of the Manual, ready to create a Commuter Train.  When I went to drive the loco from one end of the layout to the other, I discovered that the connection between TC and the Lenz system was broken as none of the locos nor the turnouts would respond.  Not to worry, I went back to the Connect to Digital System options.  No response.
Further checking back along the line showed that the whole of TC was disabled - including the desktop icon, which had changed into another icon.  Further checking showed that the whole of my original download had gone.  Not to worry.  I downloaded a fresh version.  Luckily, I still have my code that Jurgen sent me.  Copied and Pasted it into the box and TC is back.
However, all of my original track plan has gone.  I have searched in all my folders, but not a trace of it remains.  So, now I have to start from scratch.  Kind of like scratch building in cyberspace.
It is really very trying, to say the least.  :brickwall  :shock:  :brickwall  :shock:  :thud
Well.  Well.  Well.  Well.  Rummaging around in my new version of TC, I found my old track plan.  I recognised it from the name I had cunningly given it (Track Plan 1).  When I tried to open it, I got a dialog box which told me that it has been created with an old version of TC and my new one can't open it.  :shock:
So you will be a happy chappy here this arvo?
I normally have a short fuse as you know, Sol.  However it has surprised me how calm I am.  I guess with all the drama that has gone on so far, it's only a minor set back.  At least I know how to rebuild it.  I find it more frustrating when I don't know what to do next.
I guess it's character building.  :mutley
