[user=269]MaxSouthOz[/user] wrote:Text insertion is not one of TC's finer points………………and requires patience :roll:So, I'm not making much progress. I'll try putting some text in. When I hit the OK button, I can only see text in two of the squares. I tried right click dragging, left click dragging Ctrl dragging. No luck. I finally froze the computer.
I think I'll go and watch Inspector Rex until someone saves me . . . :thud
Make sure you are in edit mode ie no spanner
Left click on the the first square to select it
Right click and drag to expose all the letters
I have done the same thing Max……………….too many clicks in unexpected directions and Mr Gates and Mr Freiwald in combination get extremely chilly…..freezing in fact
Geoff is correct…………….have you tested that the computor will physically move a point in operational mode
do the addresses in the computor (on the connection tab) match the addresses in the LS 150
Notice I use the plural………….each of the two motors has to have a unique address……………and they should each be connected independently into the LS 150
HTH…………let us know how you get on
I reckon that's what I have been doing. I'll try it again.
The turnout should physically move when you press test (even in edit mode)…………the whole idea is that match the movement on the screen with the actual. If they dont match you adjust the computor + and - ……no need to do any re wiring……its really cool
According to the connection box, they have the same addresses as those in the LS 150. The Edit button is always highlighted, so I don't appear to be able to go into ops mode at all. The turnout icons change both in the box and on the plan, but nothing happens with the turnout motors.
I know the motors are working via the LS 150 as they will operate both with the LH 100 and with the Zug software (so the L1 USB is working as well). The TC software is not connected to the Lenz system.
Isn't what I have described above, setting the accessory decoder (LS 150) addresses in the point properties in TC? Perhaps not. It's not a stupid question, Geoff; I just have no idea what else to do.[user=269]MaxSouthOz[/user] wrote:Now I have all the turnouts configured and named. I put in 2 seconds just to be sure. I'm not understanding the text about testing them. When I click on them, the Ops icon appears and the symbols change, but I don't hear the satisfying zzzzzzzzzzz from the Tortoises. The Edit icon is still hilighted. Yes, I have the layout turned on . . . :lol:
The LS 150 is working as I can change the turnouts both with the LH 100 and using Zug on the computer, but nothing happens when I change them in TC. I told you I was thick! :oops:
Max, have you tried clicking on the points in the Switchboard window when in operational mode, not edit mode? When I do that, the route for the point direction changes on the schematic in the window AND the point in question moves due to the command sent to the accessory decoder.
(Stupid question, but I suppose that you have set the accessory decoder addresses in the point properties in TC?)
If you click on this icon you should be able to Toggle between [Operate] and [Edit]………….if you are in operate mode the icon at the end of the mouse arrow looks like the icon in the menu…………its covered in the tutorial in more detail
I am not sure exactly how you are running your system but there has to be some way that TC is connected to your DCC system……..in my case it is through a Lenz USB ………….you can see it on the turnout shot I sent you……what connection are you showing on your turnout connection window?
There is a section in the Tutorial dealing with connection…………….
Select [Railroad] in the main TC menu then
Select [Set up Digital System]
What do you see?
I don't think I've done Set Up Digital System. I'll have a look for it.
I'll let you know, John. Thanks.
BTW, do you think the LEDs will be helpfull? I'm on my own here, so I need to set things up to cope.
Establish which Com Port your USB is connected toI'm using the L1 USB, the same as you. I can see it in the connection box window.
I suspect that in "Set up Digital System you may see " Lenz USB off line" select [Change] then select [Select Port] scroll down and choose the Com Port
As a test set up a train window (assuming you have an engine set up)……if you are connected the direction arrows will show green and yellow and you will be able to operate the loco………….I always do this because it is easy to get the sequence wrong if you are bouncing between Lenz DCC control and RR& Co Control
I thnk the LEDs are a great idea…….I didnt intend to put you off with my "Two Person Job" its just a bit finicky as you play with all the combinations
What do you see?
I see Connected Digital Systems "Lenz Digital Plus/ LI 100(F) COM 1 when I try to add it, I get a box which says the Port is Offline. When I proceed I get a box which says it cannot connect to the digital system. Ensure that it is turned on, which it is because I can drive the Zug software.
This is why I can't operate the turnouts. I need to find out now, how to connect TC to the Lenz. :???:
I tried COM 1. There are about 250 of them. I'm wondering if the USB/TC doesn't like being connected through a powered Hub. Rr&Co suggest a hub as a good idea to save the connector pins on the stick.
Maybe I should try plugging the USB LI straight into the laptop? I can only try it. Otherwise it should be COM 1.
OK progress
Select Set up Digital Systems
Then scroll down until you get Lenz Digital Plus/USB
You are connected to the wrong Lenz interface
But then you need to get the correct com port
In Windows select Control Panel
Device Manager
Hardware
Scroll down to LPT/Com Ports
Open it up and you should see the comm port Lenz USB is connected to
That should work
The Zug uses the L1, so it should be the same port. I'll try Johns tactic and report back.
My desktop (which I'm on now) also had a keniption today. I've had to put a new battery in the tower. I bought a powered hub for hit while I was at it. What with Skype, 1Tb ext drive, printer, video cam, still cam, wireless keyboard et al., it's all a bit Heath Robinson under the desk.
Normal service will be resumed as soon as I have an aspirin, a cup of tea and a good lie down, as Granny used to say. :pedal
I think you said that you are using an old computer and that it is connected to a hub. I don't know whether you know, but as I understand it, the Windows (including XP) registry, remembers every device that is ever plugged into the USB and assigns each to a unique COM port. That means that even if you plug in a device that you last connected a year ago, Windows will still assign the same COM port to it.
Sounds good and sensible, but there is a snag.
Although there are lots and lots of COM port numbers shown (128 in Windows XP, I think), the actual code (unmodified) can only handle 16 assignments!!! My knowledge may be out of date, but may still apply to an older machine. I wonder if you have already had 16 different devices connected to this computer in the past, and that it is unable to assign a COM port to the L1/USB??
This is the error message I got:- "Cannot connect to the digital system. Please ensure that the system is connected and turned on. Retry."
Now I KNOW that the L1 is connected as I can open the Lenz Server. Besides which the red and green LEDs are alight on the L1 - and the yellow LED flickers when I run a loco with Zug.
I'm off to burn myself some dinner whilst youse Gurus ponder . . .
Is it time to post my problems on the RR&Co forum?
I went back to my computer. I Uninstalled all of TC - including the empty folder in the C drive Program Files.
I removed the RR&Co stick from the USB hub and restarted my computer. Went to www.friewald.com and downloaded a complete new Gold version. I used Run instead of Save. At the completion of the installation, the software opened TC.
I was asked for a code or to insert the stick. I inserted the stick and closed the box without hitting Continue and the demo schematic opened. I connected TC to COM 4 and opened a blank schematic. I put a turnout on the page and gave it a number, went into Ops and clicked the turnout icon. Then came the sound of the Tortoise springing into life.
Clearly my previous playing with the old schematic during the free trial time just wasn't compatible. I was avoiding having to make another track plan - that was the problem. I reckon the other critical thing to do is not insert the stick until the software asks for it.
Anyway, thanks to all for your efforts. Now I have to draw my track plan again. Not to worry. It's worth it to get past this bottleneck!
:Happy
Glad you have got it working, Max. I wonder, however, if it is actually still in demo mode? I didn't think it was supposed to stop every 15mins when the stick was seen to be present. As you know, I have not purchased the stick yet. If I keep the computer connected to the controller, it does the same, stops every 15minutes. However, if I disconnect from the controller - either within TC software or by turning off or disconnecting the controller, TC keeps running. I find this useful for working on schematics and the like.
Likewise Max :doublethumb
However it shouldnt be stopping every 15 minutes…………..it must think it is in Demo Mode still
Try cleanly closing down all the programmes and then the computor itself……………..dont disconnect the LI USB or the dongle
Reboot the computor
Start up TC
Your layout should automatically appear without the dialog box asking for a code showing at all
All will be well shortly :cheers
