RR&Co
(In Topic #13115)
Switchboard
Hi AllI an using RR&Co 9 , NCE php . running Windows 10
I am trying to insert a track diagram , from my photo's
folder . Into switchboard . I have managed to insert the
drawing into animator , but I can't move it into a switchboard .
Any feedback will be most welcome .
Regards Ted
If you have a photo and you want it to appear in your switchboard then there is no need to use animator.
From the TC menu open the accessories tab.
Locate the Image icon and click on it.
Move the mouse and the arrow pointer will turn into a spanner when you hover over the switchboard.
In the location you would like to insert your photo click and the spanner will turn into a box.
Right click on the box and click properties
A window will open up - select browse and locate your file in your photos folder - the default option is BMP format but you can select GIF or JPEG files
You can then select the pixel size when ready hit the OK button
Photo will be inserted with its top left hand corner in the box you selected
Photo location can be dragged to suit your preferences.
Last edit: by gdaysydney
Thank you for your reply . I have managed to move the
track diagram into the switchboard , as you instructed , but ,
Now I want to use the track diagram as a switchboard .
as it is a photo , I can not activate the photo . I have tried to
delete each track and then redraw it with a new track , but this
do's not work either .
Any further ideas would be most welcome .
Regards Ted
I have , over time collected parts of track
layouts on another computer . These I have incorporated
with alterations into what I would like as my track layout .
Really , I was just being lazy , There is between 150 and 200
meters of track all told on four different levels . Which I will find difficult
to draw .
Now I will try to draw each level on separate switchboards , and see how
I go
Thanks again John .
Regards Ted
Thank you for your prompt reply
I will read up on connectors .
Since upgrading from controller 8 to 9 ,
I have been concentrating on converting
my workshop ,into my new train room .
So I have been negligent in properly reading up on
the differences between the two .
( see relocation )
Thanks again .
Regards Ted .
