reverse loop
(In Topic #11881)
short lack of power
i have an onguard reverse loop module and a reverse loop with insult joiners at each end.when the loco enters the loop it stop as soon as it joins the loop connection i have to push the loco into the loop then it will carry on through and out of the loop
has anyone got any idea why the loco is stopping please
Using DR5000 12x DR4088s loconet
DR5033s
Ecos System
Train Controller
iTrian
arduino
Var
DR5033s
Ecos System
Train Controller
iTrian
arduino
Var
thanks for the advice
DR5033s
Ecos System
Train Controller
iTrian
arduino
Var
DR5033s
Ecos System
Train Controller
iTrian
arduino
Var
It seems as if your engine is picking up its power , from the FRONT wheel on one track ,
and the REAR wheel on the track . Therefore when the engine is straddling the insulated joiners ,
BOTH wheels are picking up the SAME polarity .ie both either positive , OR both negative.
When you push the engine forward, power is returned when the REAR wheel passes over the
insulated joiner, and both positive AND negative power are available.
Hope this might be of some help ,
Regards Ted
Last edit: by Sol
