I also have painted white metal figures from P & D Marsh, painted plastic ones from one of the German firms (Noch or Preiser, I think), and quite a few more unpainted ones from Hornby, Hatton's, Preiser, Monty's/Dart Castings, and some from local model casters here in Oz. It is good to have a variety of characters and positions.
I think "prat" (noun, a foolish, stupid or incompetent person) should be reserved for those who genuinely fit the description. Pastel summer linen jackets are de rigueur here in the south for gentlemen, as are pastel shorts for the well dressed office worker in Bermuda.Hi Jeff. Thank you again. I will have to do some serious investigating, but whichever ones are already painted are probably my best option. I don’t know if you have heard of the TV Programme “ Great British Railway journeys,with that prat Michael Portillo? But I was tempted to buy a model of him to stick somewhere, but I thought that it would lower the tone. Best wishes Kevin
Sorry for the interruption.
Best wishes Kevin
The 'Tin' HAL is a resin kit mounted on Hornby 2 BIL chassis (with the SR 2 BIL bought at a bargain price). Any other 2 BILs and 2 HALs are the Hornby models, some straight out of the box, others with livery tweaks (like full yellow ends) or weathering, or even renumbered.
I remember the Triang 'H O V I S' advert. Those units basically had a 2 BIL front end grafted onto a short BR Standard suburban coach body, so were anything but accurate. Notwithstanding that, they looked good, and I still have a couple floating around in the stock boxes somewhere.
Last edit: by SRman
The colour of the centre coach is not quite right yet. Also, the couplings are wired through to the driving trailer to allow its lights and headcodes to work. The real units had semi-open layouts, so the seating unit is not entirely correct but I can live with this.
Here it is, posed on the layout but definitely nowhere near its final position. That has yet to be decided.
P_20190904_211757_vHDR_On by Jeffrey Lynn, on Flickr
P_20190904_211724_vHDR_On by Jeffrey Lynn, on Flickr
N Class on Unigate Creameries Milk Tanks - 1 by Jeffrey Lynn, on Flickr
I used Krystal Klear to glaze the windows; you could just as easily use a little PVA glue, or have broken or boarded up windows.
IMG_20171129_191610 cropped by Jeffrey Lynn, on Flickr
The Ratio provender store is painted but not yet weathered. You can see the base grey colour I have chosen, which doesn't look too bad as it has dried dead flat.
Dapol Working Semaphore Signals Wired Up - 1 by Jeffrey Lynn, on Flickr
I have been doing a little more work on two resin LSWR brake vans from Smallbrook Studios. I have fitted the roofs, although one needed a complete replacement as I wasn't happy with the job I did on the earlier example. The D.1541 road van still has a little too much overhang on the new roof, but that is easily fixed. Aside from fixing up the paintwork, most of what's left to do is fitting handrails and adding transfers. Both vans are quite capable of running on the layout as they stand now.
P_20190926_110437_vHDR_On by Jeffrey Lynn, on Flickr
P_20190926_110510_vHDR_On by Jeffrey Lynn, on Flickr
An even longer term project has been the detailing and upgrading of an old Triang L1 4-4-0 locomotive. I added separate handrails and pipework many years ago, and put full-sized scale diameter (27mm) wheels on it. However, as Triang locos already tended to sit rather high, this put the buffers a full 2mm too high compared to "normal" stock. So, discouraged by this, I have left it sitting in a corner of the workbench for some time. Anyway, inspired by a couple of other BRMA modellers' efforts using 24mm diameter wheels, I ordered the replacement driving wheels a week or two ago from Scale Link's website, and they turned up today. The appearance suffers a bit from the too-small driving wheels, but it seems a bit more practical as a usable model. Work still needed includes adding numbers, crests and BR mixed traffic lining, a 5-pole motor and DCC decoder once all that works properly.
P_20190926_110616_vHDR_On by Jeffrey Lynn, on Flickr
Aside from this error in the Heljan Westerns, I do rather like them. They are less delicate than the Dapol ones (a little less detailed too), but they run more quietly and seem a lot more robust.
​​​​​​​P_20190928_182554_vHDR_On by Jeffrey Lynn, on Flickr
