but when it I got confirmation, I had clicked the wrong one?? But I got a refund. Please advise, on which standard are the. Kernow 205 modelled ( bearing in mind? The Bodge Job done when building the Tunnels on the Hastings Line) where special "Slim Carriages are required to fit the Tunnels. All the best. Kevin
3R Tadpole DEMU - 1 cropped by Jeffrey Lynn, on FlickrThe class 205 2H/3H units were normal width units. Some units lost their centre trailers in later life but a few had the refurbished 4 CEP trailers inserted. We're generally talking NSE and Connex liveries here.
Class 207 3D units were narrower than standard, but still wider than the Hastings units (classes 201 - 203, 6S, 6L, 6B and later 5L), and had curved sides. Again, some were reduced to 2D but a few had ex-4 CEP trailers added - these stood out rather like the driving trailers of the Tadpoles, because they were wider than the rest of the vehicles in the unit.
With the Bachmann/Kernow 2H units, the 4 CEP cars won't look out of place because they are the same width, albeit with a completely different window and door layout than the 'host' unit. Without kit-building, these are the only units you can model.
Class 205 NSE by Jeffrey Lynn, on Flickr
I also forgot to mention that the refurbished CEP trailers were also given open interiors. The amount of modification you do (or don't) do depends entirely on how much compromise you are prepared to accept. Personally, I would be inclined to disguise the CEP trailer windows slightly, and leave the interior alone. The windows would have to be popped out in any case to allow easier repainting into NSE livery. At least, being in the centre of the unit, you would only be looking at masking off for straight lines with that livery.
For curiosity value only, there were three class 207s with CEP trailers, and these were in NSE livery to start with, and at least one went into Connex livery after that - they were renumbered 207 101 - 103.
The Powered bogies will have to be cut and shut to lose 1mm from the wheelbase but, as with the previous class 455/8 and 319, the blank sideframes on the Replica Railways motor bogies can be used to reinforce these, using the Bratchell sideframes as cosmetic items only.
Bratchell Class 455-9 Under Construction - 7 cropped by Jeffrey Lynn, on Flickr
Bratchell Class 455-9 Under Construction - 8 cropped by Jeffrey Lynn, on Flickr
Once again I have had a little difficulty with poor light and the black ABS plastic Bratchell used for the driving trailer sides.
The 3R unit I pictured before has a hardwired TCS M1 and a single Black Beetle motor bogie. The class 455 I'm working on has a Replica Railways chassis which is DCC-ready (8-pin socket). My kit-built Underground trains have two Black Beetles each, hard-wired to a single TCS T1 decoder in each unit.
Wherever possible, I prefer not to hard-wire. Even my three Peckett tank locos have their decoders wired to the Hornby 'blanking' plug, to ease changes of decoders if necessary later.
You can buy 8-pin sockets to hard-wire into a locomotive or unit, which allows you to then use any 8-pin decoder you choose.
Incidentally, even though the TCS T1 decoders have been hard-wired into my three Underground units and into a double-motored Triang Hymek, the T1 actually has a 9-pin JST connector to its wiring harness, allowing the decoder to be swapped out without having to unsolder anything.
Rather than chance.damaging the Decoder . All the best Kevin
The bogies have been assembled, although the motor bogie sideframes remain to be cut down and fitted. I have adjusted the ride heights: I found that Hornby's valve gear spacer washers worked well, with one thick and one thin washer added to each of the trailer bogie mounts.
Bratchell Class 455-9 Under Construction - 10 cropped by Jeffrey Lynn, on Flickr
Bratchell Class 455-9 Under Construction - 11 cropped by Jeffrey Lynn, on Flickr
Bratchell Class 455-9 Under Construction - 12 cropped by Jeffrey Lynn, on Flickr
The roof ends need trimming, and all the gaps need to be filled, but the basic shape is there and it is already capable of being run. Small details to add include the brake wheels and the vacuum pipes, with lamp irons having to be fabricated from some wire.
I used Hornby 14.1mm coach wheels, and NEM fishtail pockets with the actual fishtail bit cut off. A small fillet of wooden coffee stirring stick fills the recess in the bogie frame end, allowing the pockets to be glued at exactly the right height. I cheated slightly in using the correct wheelbase for mounting the bogies, but trimming off the end overhangs from the inner ends of the sideframes to allow a little extra swing. This vehicle will go around the tightest of model railway curves if required!
Last edit: by SRman
Last edit: by Marty
The blue is a base coat only, and is both too glossy and too light. Once I get the vinyls, I will be able to paint any areas that still show to match the vinyls. I found with the two 450 units i did with the vinyl overlays that First Bus 'Barbie Blue' was a very close match (just very slightly darker, which was fine for the roof areas.
Following along.
I am still awaiting the vinyls from Electra, which will allow me to match the colours properly.
