I find that, just like my TV or stereo, the volume knob is about 1/4 to 1/2 up; and the sound is rich and plenty loud enough.
"Mega bass" speakers have a lot more cone movement, and get lower bass output.
Anybody interested check out https://sites.google.com/site/markgurries/home/dcc-projects/two-way-speaker-system
It's a pretty simple circuit that can be tuned . There are many more.
I've tried those so called bass boost speakers. A waste of money.
My system works for me.
All the best. Kevin
Where expensive sound decoders are involved I don't blame you for being cautious. For the 8-pin versions of the LokSound decoders which have the speaker wires already soldered to the decoder (and usually come with a standard 23mm round speaker), I play safe by cutting the wires half way along, so that any soldering of wires or joints is done away from both decoder and speaker(s) - keeping the heat away from them as much as possible, and also allowing a safe margin for any cack-handedness.
Good point about cutting the wires. Rather than use solder to reconnect, use 2 pin connectors (Miniatronics or similar), and a metal heat sink between the join and decoder (I have some metal clothes pegs with flattened ends that clamp on the wire). One thing I've found useful when fitting multiple speakers is to lay them out, face down, and all in the same orientation. Mark one terminal with a red felt-tip. That way you ensure that they are wired in phase. Two speakers sounding louder than one? - I have a feeling that could be subjective. What you can do with 2 speakers is to up the output, given that we normally drive one speaker at 30-50% power. I know with the QSI board it is louder, but that's with 2 amplifiers.
"Mega bass" speakers. Max, I agree with you, WOT as most of the time they sound distinctly muddy. There is a reason for that. They need a crossover to make sure they are only receiving the lower frequencies (below 1-2 kHz). and the other speaker is only receiving above 1-2 kHz. That's why audio speakers have crossovers, bass speakers are useless when it comes to higher frequencies. Bass speakers also tend to be non-directional. I'm tempted to try a crossover design on one of the brass coffee grinders (4-6-2 Pacific) which has a really big tender with room enough for a dedicated crossover circuit and a large bass reflex speaker, and plenty of space in the boiler for a "tweeter". The brass Tenshodo SD7 (C-C) also has plenty of interior space for the circuitry and speakers. Rule 1 applies here, as audio is highly subjective.
We hear between 20 Hz and 20 kHz, which is a wavelength of 56 feet to around 0.6 inches. I'm amazed that the designers of small speakers can get them down to 300-600 Hz by messing around with the cone throw and/or air mass throw via baffles or porting. Way beyond me. One problem with cheap sound decoders is that they also come with cheap and often inappropriate speakers. Swap them for a decent one and the sound is much better. Something to watch for with the forthcoming Hornby entry-level sound decoders.
I see DCC supplies has a bass reflex speaker which is a ported design, and is supposed to achieve lower frequencies. Looks to be a Zimo product. No specs that I can find, so who knows. Zimo also do hyperbaric speakers. Watch the power requirements for these specialized speakers, they can be relatively inefficient and need 3 watt drivers. OK for the O scale folks, tenders only for us common mortals in HO/OO as the decoder boards are big. Which rules out most diesels with that big lump of metal chassis inside.
Kevin - good decision, if in doubt get somebody to do it.
I am still looking for a "Man Cave" with a house attached, and that is really distracting me from doing much with my layout plank(proving ground work) and all the other jobs. All the best. Kevin
Anyway, in trying to get smoother and quieter (no chattering!) low speed running on E5003 (my non-sound fitted 71) I have played around with the settings on the Lenz Silver+ 21 decoder through Decoder Pro on the computer. I turned off the BEMF completely, then tweaked the start voltage to a value of 14 (after several experimental values ranging from 1 to 15). There is a bit of a delay on moving off when the throttle is opened but the slow running is absolutely dead silent now, as it should be.
After all of this, though, having temporarily tried a TCS EU621 decoder which gave beautifully smooth running through the whole speed range but messed up the lighting functions completely, I have ordered a Zimo MX634D, and when that arrives I'll pop that in to see whether I can improve things further.
Now, to the other problem with E5003's lighting; I had worked out that by remapping a function to work aux 3, the headcode lights could work even with the four function ESU decoder. It seems that Dave Jones designed the PCB so that it allows for logical outputs too (it has an amplifier circuit to allow power to be fed to anything attached to the aux 3 output). However, when I set it up, the headcode lights went out when I selected the cab lights at one end. I solved that by rereading the function mapping sheet in JMRI, and worked out that I must have gone a bit cross-eyed when I ticked the box for F20 on line 28 … what I had actually ticked was the 'off' part of F19. Having now corrected that, the headcode lights work as they should when F20 is selected for the ESU LokSound decoder. JMRI Decoder Pro makes it so easy to do these things without ever having to know which CVs you are changing or the values needed.
The lights were a bit bright so I dimmed all of them a bit while setting up the profiles in Decoder Pro, but after the photos were taken I dimmed the lights even further.
Last edit: by SRman
Both class 71s (or HAs, if you prefer) are DJM models. E5004 is in early green with red and white stripes, E5003 is in the later, slightly darker green with small yellow panels and no stripe. Neither has the full front valance fitted, although they are included in the bags of bits. Both have tension lock couplings, as supplied, fitted at both ends.
Bachmann and Hornby locos and units are not too difficult to renumber. I remove existing numbers with any of a number of different methods.:
1. T-cut (or many other equivalent car cutting polishes will do the job). They do remove a layer of paint so don't rub too hard but be patient and get a little off at a time.2. Wooden cocktail sticks. toothpicks or lolly sticks will abrade the numbers. Again, be patient and take your time.
3. Track rubbers or ink rubbers will remove the numbers quickly, and also a layer of paint. These can leave a rough, slightly discoloured patch, but a quick, very light polish with T-Cut fixes that.
I use waterslide transfers available as complete sets from ModelMaster, but Fox Transfers also offer similar styles.
I haven't any handy photos of renumbered units, but if you look back a few posts, you'll see Bulleid light pacific 34072 that was renumbered using these techniques and ModelMaster transfers and etched plates. I had to remove the top layer of weathering over the numbers as well on this particular model.
I have also been a bit lazy on some renumberings in the past, changing only one or two numerals, but if the colour, typeface and size don't match exactly, they do show up the differences. A touch of weathering can sometimes help, but not always. This can be seen if you look carefully at my SLW class 24, renumbered by taking off the last numeral only from D5016 and replacing it with a '7' from an HMRS sheet of BR numbers; the '7' is very slightly shorter and whiter than the other numbers. I may correct this some day.
Last edit: by SRman
In the unlikely event you mess up the new ones, they'll come off again even more easily so you can have another go. It'll be good practice for your modelling skills and also give you a sense of achievement when you successfully finish the model; you will have something that is unique to you and your collection.
:cool:
PS Jeff did you ever have or look for an 0-6-0 P Class, especially in DCC?
Even so, with the discussions elsewhere on top speed at the back of my mind, I decided to video trains running at what I consider "reasonable" speeds for my layout.
Using my NCE Power Pro system with a 15 V power supply, the two DJM class 71s are seen here with E5004 with Lenz Silver+ decoder on a Pullman train with lights on speed step 91 (out of 126), while E5004, with ESU LokSound v4 decoder is on a milk train at speed step 43.
While they could both go a little faster than this, it wouldn't look particularly comfortable in my layout's setting. I'll let others be the judges of what would suit their wants or needs.
[yt]p62WY_86HOw[/yt]
Last edit: by SRman
