The more I think about? whichever stock/Year it was? The Guards compartment that I'm referring to was the only one in a "Box", Meaning that it had been a driving cab , hence the nickname "Horse Box" . Every other stock DM had a glass partition and air worked Guards door. But let's not spilt hairs over my recollections.
All the best. Kevin
This is a combined photo of the two Q27 cars - the mixing of the two photos into one can give a few minor odd effects.
I have to add some sort of headcode and destinations to both ends, Also, I don't know if anyone has noticed, but I haven't fitted the shoebeams to the Q27 DM yet.
As for kits, I just did another "quickie" Cambrian kit, for a second LSWR open wagon, but I chose to do different braking arrangements on this one. I didn't bother masking off the wheels and bearings as the wheels themselves benefit from being painted (the treads can be cleaned off with a rotary wire brush in the Dremel), and the bearings are protected by the wheels themselves.
Also going through unbuilt kits, I have recommenced work on a four car A60 train. I had painted the body shells a metallic silver, but I just don't find that convincing for the dull aluminium finish on these trains. I tried overpainting with Humbrol "aluminium" colour, knowing that it dries dull, but that also dried too dark, so I have now painted the bodies in Humbrol light grey #126, which I think is actually more convincing, in conjunction with a darker grey for the driver's doors and all of the corner pillars, plus an even darker grey for the roofs.
Next I'll have to assemble the white metal bogies and paint the underframes and floor units.
I bought some seat units off Radley Models to suit as well. I may have to find suitable motors for it: I have only one Black Beetle spare (not enough for a four-car unit), so may have to resurrect some Tenshodo SPUD motor bogies I have filed away. I believe they can be converted to DCC.
I'll post photos soon.
After that I have a four-car C Stock set to do. If the greys work out well on the A Stock, that's what I'll do on the C Stock as well.
I have a train of CO/CP Stock already running, with one more white metal trailer car to build when I feel inclined to do so; that will make the CO/CP train up to six cars (2 x three-car units), where it is currently five cars (1 x two car unit and 1 x three-car unit).
One generally doesn't fold white metal; the parts are usually castings with a small amount of flexibility to allow straightening if they get bent in transit.
Many of the older white metal kits have been converted to resin kits with one-piece body shells, where before the white metal kits used multiple separate pieces to form the sides and ends, as in the demo photos below (actually taken some time ago). These show a couple of F Stock trailers, but the principle is the same for other such kits.
Edit (additional info): note on these kits the roof was in two parts with a connecting piece in the middle. I had already glued the end castings to the roof ends here, allowing me to ensure that the finished sides matched the length required, as there was a small amount of leeway in the fit of the side components.
Radley Models does have R Stock resin kits available. You would have to combine those with Q38 DM cars to get a full set (modifying the Q38s slightly to become R38, R47 or R59 DMs).
Card kits can be made more robust using reinforcements and something like shellac, but that would also discolour them if you wanted to retain the printed liveries. Some of my earliest modelling efforts used card, making buses and carriage sides for starters.
Last edit: by SRman
Changing subject slightly, I have commenced work on the A60 Stock bogies and motors - unusually for me, I'm using two Tenshodo SPUD motor bogies that I have had in storage for years. I have tested these and they run fine on DC, so the next step is to wire them for DCC. To that end, I have pulled the brass contact strip out that connects with the brushes, and folded it upwards outside the motor housing to allow direct soldering of the pickups to the red and black wires on the decoder. the brushes have two tags sticking up out of the top of the bogie, which I previously soldered wires from remote pickups to, but which will now receive the orange and grey wires from the decoder.
I have some TCS M4 decoders free, so will use two of these (one for each power bogie). The four functions available on these decoders will allow for future lighting options.
Anyway, here are a couple of photos showing the very early stages, where I have screwed the adapters to the SPUD motors and glued the sideframes on to those, and I have glued the top-hat bearings into the bogie sideframes, then the bogie stretchers to one sideframe only, pending attaching the other sideframe and sandwiching the axles at the same time. The SPUDs had spoked wheels fitted already so I'm leaving them as is; LT tended to mix types of wheels quite indiscriminately on earlier stocks, but I'm not too sure about on the A Stock. With the solid bogie design, this won't really show much in any case!
Note the old 'credit card' style Hornby Club card I'm now using as a mixing palette for the Araldite two-part epoxy. I can only mix small batches at a time to work through the fiddly assembly bits.
If you look at photos of A Stock in service in the 1960s, I think I have got closer to the effect of weathered aluminium.
Last edit: by SRman
In the meantime, I have now wired two TCS M4 decoders to the motor bogies and tested them successfully on DCC. I arbitrarily allocated an address of 40 to both, but I haven't actually worked out numbers for the unit yet. This just follows on from my other underground sets, where the first number was allocated according to the last two digits of the car numbers of the 2-car motorised CO/CP set (37). The F Stock (with cars still unnumbered) became unit 38, and the Q Stock is 39, so logically the A Stock will be 40.
Just to throw a spanner in the works, the S Stock is 87 - the two motored cars have last digits of 87 and 88.
Back to the A Stock, while I have put all the bogie and underframe parts back in the box, I have continued painting and touching up the body shells, and can also start on painting the seat units, so progress is not entirely at a stop.
I recently re-chassised a Bachmann London Transport Pannier Tank, L91, which used to have a split chassis but now has a DCC-ready chassis donated by a BR black example I bought at a reasonable price off eBay. Because of its origins, I have had to repaint the wheels and coupling rods; they are still a bit shiny but some judicious weathering should fix that.
Also recently completed is a Cambrian Kits LSWR open wagon, which has joined a pre-grouping train of kit-built wagons, including my previously built LSWR open and two LSWR vans. I have chosen an alternative brake arrangement on the second open wagon.
Also pre-grouping is the Bachmann LBSC E4 0-6-2T, which now has a crew fitted. I have been buying pre-painted loco crews as well as painting a few more myself, and had a minor blitz on putting them into some locomotives, including a Merchant Navy, a Standard 4MT 4-6-0, a Beatty well tank, two E4 0-6-2Ts (the other one being a BR lined black example), a C class 0-6-0, a 700 class 0-6-0, and an N class 2-6-0. There are still more to do, although tank locos tend to be more difficult to do, particularly if the cab roofs are glued on too well.
Finally for now, I have found a colour I am happy with for my London Transport A60 Stock train - a 'flat aluminium' colour. This four-car unit is under construction, but is presently held up awaiting wheels with a suitable axle length (ordered but not yet here). I fitted the side frames to the motor bogies (two Tenshodo SPUD motors), followed by wiring two TCS M4 DCC decoders to the motor bogies. The M4s will allow for future lighting to be fitted and controlled. The body shells in the photo are still in the process of being painted, so have some rough edges apparent.
