I have a good photograph of the pantograph well, kindly supplied by another modeller, so used that as a guide to make up something resembling it, albeit rather cruder. Some of the plastic sections I have used are not only too big, but also the wrong cross-sections, but I had to use what was available. The insulators are from Somerfeldt. There are still a few finer details to add, but I think I have captured the effect, if not quite super-detailed.
And after adding a couple more details and painting:
The pantograph is sprung and capable of being used, but on my layout it will only ever be in the down position, because it is all on third rail!
Last edit: by SRman
The third (and fourth) rails are purely cosmetic. Live ones wouldn't gel too well with DCC.
At a later stage I will be fitting working head and tail lights to the driving trailers.
The Krystal Klear I used as the glue was still wet and milky coloured in places when I took the photo.
Last edit: by SRman
Another recent project on my workbench: an LT pannier tank, L91. This is actually a new locomotive wearing old clothes! L91 was an earlier release from Bachmann with the dreaded split chassis. I hard-wired a DCC decoder into ti, and the running was good apart from a constant waddle. I replaced several of the wheelsets, but still none were entirely concentric. Eventually, I managed to get a much newer pannier (BR black 9759) with a decoder already fitted. With some very minor modifications, the old pannier body sits very nicely on the new pannier chassis.I replaced the cheap Bachmann decoder with a TCS DP2X-UK decoder for better running (not that the Bachmann one was too bad, but the TCS one allows a lot more fine tuning).
I need to repaint the wheels and coupling rids on the new chassis, but that won't take long to do.
L91 is seen here with much newer DCC-ready L89 behind. The shades of red are quite different, but looking at photos of the real ones, it seemed to darken considerably over time with age and weathering.
I may try to sell off the old chassis and the black pannier body later. The new body doesn't fit the old chassis particularly well.
It was a real shame to paint over the lovely finishes on these two but it had to be done.
All five coaches have only had one coat of brown so far, but they are starting to look the part. The two brake coaches have Cherry Paints' LT brown, while the other three have two different standard Humbrol browns while I assess which colour best represents the rather dirty brown these coaches ended up in. The Humbrol leather #62 used on the two most recent ones seems a little light but may actually weather down better.
Anyway, here is the full train posed with Heljan LT ex-Metropolitan #8, Sherlock Holmes.
Also off the workbench is a class 25 which has been on the bench for a very long time. It is a hybrid Hornby body on a slightly shortened Bachmann chassis. The underframe still requires me to build a new boiler water tank, because the Bachmann model was a later style locomotive built without this feature. It has been numbered as D5183, which I have photographic proof of having visited the Southern Region. It was also a complete repaint from a blue TOPS numbered body shell.
D5183 is seen here at the end of a line of Derby Sulzer type 2s, on the viaduct over Newton Broadway LT station, with the other two locos being Sutton's Locomotive Works class 24s, D5017 and D5000, which were both Southern allocated locomotives between 1959 and 1962.
Longer term, I'll replace those roofs with flatter profile roofs, either by adapting the existing ones or by buying some elliptical roofs from somewhere (Ratio?). Later still there is heaps of potential by cutting-and-shutting the coaches to form more realistic layouts of first, second and third class compartments, maybe even with toilets as well.
To show the effect, I have repainted the first coach, although the roof is in dark grey here - I subsequently painted the whole roof matt white, which looks better.
Question: Is this accurate?
Answer: Not on your life! Like the LT coaches, it is representative only; something to capture the atmosphere of the times.
If I go for the correct livery? My Hornby M 7, follows the National Railway Museum M 7 ( some collectors don't like the accuracy of the livery). And I notice that your M 7 is a different livery to my one , strange that?
all the best. Kevin
there have been two M7 releases in LSWR liveries; I have both! The other one is 252 in Adams' pea green edit: correction: Urie loco green, a plainer livery than 245 in the previous photo.
I have a set of four of the Roxey coaches plus a luggage van, but it will be a very long time before I get around to building them.
M7s in LSWR days were used extensively on suburban services out of London, and could be required to haul long rakes of heavy wooden coaches. One photo I have seen had 11 coaches behind the drawbar. Mind you, I very much doubt the Hornby one could manage that sort of load.
Last edit: by SRman
Also added were 'London Transport' underlined fleet names on the DM cars only, and 'No Smoking' roundels on appropriate windows, gleaned from photos in various books I have.
All the best. Kevin
