Incidentally, I was wrong about my SR concrete hut being movable: I have, at some time, glued it down to stop me accidentally knocking it all the time, so it has to stay for all photos!
Last edit: by SRman
I think the open wagon will also look better when I get around to doing it. I'm fairly sure the smaller letters are correct for the Mink D, though, but if anyone knows better, please advise me.
Last edit: by SRman
Modelmaster are expanding their range into pre-nationalisation so they're worth a look.
Fox also have a useful selection of transfer.
All three brands are easy to use and give good results.
The smaller steps under the guard's doors are also soldered, although one of them took me several attempts before it stayed solidly put.
The whole lot is painted South Eastern & Chatham Railway (SE&CR) wagon dark grey with black below the solebars. Lettering has commenced with HMRS pressfix transfers, but is not yet complete. I have glazed the various window openings but I'm not sure that all of them should have "glass" in them - it's not at all clear from the drawings I have or any of the limited number of photos I have seen.
Last edit: by SRman
You've done a good job though. It looks great.
Last edit: by Marty
Notwithstanding that, I think I managed to get the 'W' on this side very slightly crooked.
Last edit: by SRman
If you think the glossy smoke box door looks odd against the rest of the smoke box, it is because I needed a glossy surface for the waterslide transfers I used for the number. The rest of the transfers are from P.C./HMRS, of the pressfix type. The tiny 8F power classification above the numbers on the bunker side really taxed my eyesight!
Still to do on the G16 are varnishing the whole thing to protect the transfers, add lamp irons, glaze the cab spectacles, put some coal in the bunker, and weather the lot.
The ex-SR 'Pill Box' brake van is built from a Cambrian kit and pre-dates the Bachmann model.
Last edit: by SRman
I use them within my kit-built multiple units, with the droppers cut off (EMUs and DMUs are not normally split withhin their units for everyday running purposes). Some of the Underground kit-built types also have them within the sets.
I also use them at the outer ends of all my BR EMUs, both kit-built and ready to run.
They are used within fixed rakes of coaches, such as the typical sets the Southern Region used, but I leave tension lock couplings on the outer ends. I have rakes of Maunsell and BR mark 1 and 2 coaches made up this way, as well as many Pullman coaches.
There are fixed rakes of modern wagons, like Bachmann's TTA, TEA, HHA and HTA wagons which normally run in block trains. Again, they have tension locks at the outer ends.
Similarly, the Bachmann Intermodal pairs of container wagons, which all have Kadee #17s fitted within the pairs. Many of these, and many of my other container wagons, like the Dapol FEA-Bs, pocket wagons, and Megafrets, have Kadees fitted at the outer ends, with a few left with tension locks at one end only. I can mix and match these wagons a bit, with the proviso that ones with tension locks has to go at the outer ends. Of course, it is possible to marshal two with tension locks 'face to face' within the rakes as well.
The vast majority of the Kadees I use are the NEM 'fishtail' types, numbers 17 to 20. I do have some #5 types (or similar) fitted to kits like the London Transport Q stock and my DC Kits 4 EPB, usually on the bogie ends.
I can see most of my class 33/1 diesels getting Kadees fitted and being semi-permanently allocated to the forthcoming 4 TC units I have ordered from Kernow Models. Maybe one or two of the class 73s may get this treatment as well.
At some stage I may consider doing the older style wagons to allow for shunting movements, although the tension locks also allow for remote uncoupling, but not the rather nice delayed uncoupling the Kadees allow.
Following on from the wagons, I'll need to do the loco's , but, as I have said already the Decoder and Speaker complicate things and with my hands I don't trust myself to reassemble the loco afterwards.
I have considered running a 2BIL with a 2HAL but again I don't know how to. In another lifetime? I would like a three coach "Thumper".
all the best. Kevin
Couplings withing the units are better off being left with the Hornby rigid ones, but as there are no lights in the HALs and BILs from Hornby, you could try #17s, with the dropper arms cut off (not needed as you would not usually split coaches within units during normal operations).
The Bachmann EPBs, CEPs and Thumpers do have internal lighting and also the headcode lights, so you'll have to retain the rigid couplings unless you want to lose the electrical connectivity. These generally work well with Kadee #18 or #19 couplings at the cab ends, depending on your curves. This applies to their MLVs also.
Here's a video i took of four of my units running "in multiple" (actually in a DCC consist, although they work perfectly well under DC analogue as well). Apologies for the resolution; I got the conversion wrong!
Last edit: by SRman
Bricklayers Arms Goods Yard. all the best. Kevin
I only wanted to do one van, but as the conversion uses axleboxes cut from a second LNER wagon chassis, I had to order two of the LNER chassis, leaving me with a spare pair of axleboxes for possible future use. Simon cut four planks out of the MR van sides from the centre, but I wanted to retain the moulded rivet and bracket details, so cut two planks from either side of the centre section. Unlike Simon, I used the original MR chassis/floor moulding, shortened by a similar amount as the sides. In fact, I got it about half a millimetre longer, so bodged that by adding a section of microstrip at the non-verandah end of each side.
I also wanted to do the earlier single verandah version (which would later be modified to two verandahs, but after the time period I wanted to represent). To this end, I cut the end door top and side but left the bottom in place at one end of each side, and shortened the roof to match.
I filed a recess inside the solebars in the middle, and also filed the solebar thickness down for the extra axleboxes, so they could sit aligned with the outer axleboxes with the full thickness of the solebars intact. Once glued to the floor unit, it all becomes quite strong. I used Romford 12mm spoked wheels, which have no clearance problems with the chassis cross-members, although I prefer the appearance of the slightly larger wheels Simon used. I may try out some Hornby or Bachmann wheels gauge the effect later.
Pictures of my progress to date follow.
The roof is not glued on in any of these shots. I have added some lead weight to the floor and some rectangular fillets of plastic to fill the gaps between the solebar ends and the insides of the headstocks/buffer beams.
A quick test revealed that the wheelbase is so short it will go around any of the tightest curves I can find.
I have added the turned brass buffers (as per Simon0r's suggestion in his topic), and I have substituted some slightly larger diameter Hornby spoked wheels, which somehow look more spindly and archaic, and entirely suit the style and character of the SECR brake van, in my opinion. With these wheels it runs even more freely than with the Romfords. I suspect the Hornby axle length is a tiny fraction shorter and therefore has slightly less friction in the bearings.
I have also removed the moulded gutter lines from the roof, although I have retained the moulded stove chimney, at least for the time being.
Last edit: by SRman
Looking good. Have a good day on Saturday.I will not be far away at Caulfield running my little O gauge layout.
Mark
