Keeping the ball rolling, here's the four-car set with the centre cars painted in bright red, but the roofs have received their first coat of Humbrol #66 grey.
I have posted a couple of pictures of the F Stock in running condition (although still not fully finished) on my layout thread. All four cars are now in the same colour (LT train red).
For Melbourne Cup Day, we have a public holiday here in Melbourne, so I have put in a little modelling time this morning, decorating a couple of items of stock.
First up is the Hornby class 08 shunter that I repainted into BR blue a little while back. I have not heard any more from PH Designs regarding the etched steps (I transferred the money but nothing seems to have happened at the other end), but in the meantime, I found the plastic steps I had removed from the Bachmann 08 chassis I used under my SR 15203 shunter. With a small amount of trimming and drilling of holes, these are now attached to the Hornby chassis. I am still missing one shunter's handrail at the front but that will be easily replaced with a handrail knob and some wire. I then numbered it as D3272, which (so far) is the only 08 I have found pictures of on the Southern Region that seems to match the configuration of the model, although even now I'm not 100% sure it's right.
I also replaced the single 'sugar cube' speaker (the last one I had in stock at the time) in this locomotive with a matched pair in parallel with a double mounting, from DC Kits. The sound from the Zimo decoder (Paul Chetter/Digitrains sounds) is much better now.
For quite a while, I have owned a Dapol track cleaning car, which came from Hattons with their own branding on it in grey and white livery. I repainted into blue and grey, and arbitrarily assigned a DCC number to it (1074), which I kept forgetting. I have now given it a fictional Derby test livery with white edging to the grey (wider stripes than standard) and a red band below the waistline. It is now called Laboratory 26 and numbered RDB905090 (5090 for DCC purposes, lthough I could have used the '26' instead). I'm not sure what the real Lab 26 was, or what it was for, and it almost certainly wasn't RDB905090, which probably also exists, but since the whole shebang is fictional anyway, it gives an illusion of legitimacy to it!
As this vehicle is sometimes propelled in front of a locomotive, I may add some wasp stripes to the ends at some time in the future.
Edit: I trimmed the excess red stripe off at the ends after the photos were taken.
Last edit: by SRman
Some considerable time ago, I started work on a Maunsell 0-6-0 diesel-electric shunter, using a Golden Arrow Productions resin body kit and a slightly modified Bachmann class 08 chassis. It has been operational for a while, and painting and glazing is all but complete, apart from a few very minor touch-ups required, although without numbers or BR crests.
This will be 15203 with late style crests when done.
Today, I have added most of the handrails. A quick check of photos of the real thing showed that I have a couple of small handrails to add on the bonnet top, The door locking handles and the lamp irons are still to be added, but this still marks a good step forward.
While drilling holes for the handrails, I decided to use short lengths of the handrail wire to reinforce the joints between the edges of the running boards and the plasticard extensions. These will be hidden with a little filler before repainting the sides.
The resin steps have also been added but these are a little weak, so may require the same trick of using handrail wire to reinforce the joints.
Eventually, I will have to scratchbuild the front steps out of plasticard.
Last edit: by SRman
The handrails were given a quick coat of black paint to tone them down. Eventually, all the bonnet-side ones will be in green to match the rest of the paintwork.
Close-up shots like this are extremely cruel, but show me what still needs doing, very clearly! Obvious things to do include straightening up those handrails a bit, so they are all in line, filling the keyhole slots in the buffer beams, somehow extending the footplate/running board at the front and widening the buffer beam to match, and fixing up the black and yellow stripes at the cab end, which are still a bit rough.
Looking at the photos and comparing them to the real thing, those prominent ridges along the engine top cover also need to be filed down and eliminated - the real ones are almost unnoticeable.
Still, overall I am quite pleased with the way it is coming along. Once all the body works have been completed, I can do something about sitting the body down properly on the chassis.
A fresh coat of paint, some numbers and crests from HMRS pressfix transfers, removal of those raised lips on the engine cover, and a further effort to straighten and align the bonnet handrails have resulted in these two pics.
Last edit: by SRman
I have been doing bits of work on various projects lately.
The Maunsell 0-6-0 d-e shunter 15203 has been sat down a bit on its chassis and a few more paint touch ups done. One handrail seems to have gone back out of kilter but I will fix that again soon.
I have also commenced some weathering on these projects. I must emphasise that these are only the initial attempts and all need more work before I am satisfied with the effects.
The S15 4-6-0 has had a crew fitted and some Humbrol black weathering wash applied to tone down the brightwork, cab roof and smokebox. Lots more work to do here with browns and greys before I will be able to claim it is finished!
The O2 0-4-4T has had the pipework fitted at the front and all the brightwork toned down with the black wash, plus a wash of brown on some of the brake gear. Again, more needs to be done before it is convincing. A crew has also been fitted in the cab.
And finally, the blue 08 has copped a heavy weathering using the black wash, some oily stains and a white 'dust' wash (which was not successful in representing the chalky paint effect I wanted! It got another thin black wash to compensate). Again more needs to be done but I am happy with the effect so far. I do want to redeem a little more of the blue again but that can be done by dry brushing. I also want to add a driver and a couple of shunters hanging on to the front steps and in an open cab door. After a bit more research and digging through photos, I think I need to renumber this one to D3219, which has a better match to the features of this particular model.
Last edit: by SRman
A quick renumber, using the same Replica Railways rub-on transfers as before, and D3219 stands in full sunshine with a very cruel close-up to show me what I need to do to fix the weathering. This time, I used a strip of masking tape below the baseline of the numbers to make sure I got them straight on both sides.
This is just a progress report on weathering projects. The photos were taken in fairly dim light with my HTC phone, so are not the best but illustrate what I have been doing and indicate to me what the next steps should be.
I have slightly unweathered the Hornby 08 by dry brushing some BR blue back over the black washed edges and roof panels. It still needs a lot more work before I am happy with it, but I think it does look a little better than before.
The Hornby S15 has had a little more Humbrol black wash added, over the smokebox, cab roof, footplate and running boards, tender top and cylinders, plus a very thin application along the boiler top.
The Kernow/DJM O2 has also had some more of the Humbrol wash added to similar areas to the S15, plus the tank tops and bunker rails.
At risk of boring everyone with these slow step by step illustrations, I hope to show that weathering is best built up slowly, in layers, which is pretty well how it occurs on the real thing.
Continuing with building up (and decreasing, in the case of the 08) weathering effects, here are some more progress photos, taken on the layout near Newton Broadway station.
In the case of the O2 I also 'doctored' two of the photos to resemble older images in black and white and sepia tones. They then give me some comparisons with the photos I am working from in various publications.
The 08 shunter has had a partial wash and partial dry-brush effect with grey, Humbrol #66 (called olive drab). I had to use a cotton bud and turps to feather the edges over the top corners of the bonnets. I also used a few dry-brushed strokes of rusty brown along the lower edges of the frames and brake blocks and rodding.
And to the O2, with a lot of grey (#66 again) washed and dry-brushed over most of the areas below the footplate, plus the running board top surfaces and smokebox.
And the black and white versions of two of these:
And the sepia tones. I think these look particularly effective, myself.
As before, these are still works in progress, but I am happy with the way they are going, at present.
Hi Jeff, I have tweaked your very nice picture to make it a bit more 'vintage' by increasing contrast and brightness, there is someone on here who is an eggspurt in these things, but hope you dont mind,
I think you should be justifiably proud!
Thanks for that Doug. I'll have to save that one. It looks great.
I was going to experiment a bit more myself, and add a few scratches and other artifacts that creep into old photos.
:doublethumb
I hope you don't mind, Doug, but I have posted your version of my photo in a couple of other places online.
In the meantime, I have played around with it further myself and got a few other effects. My last attempt was to add smoke and steam - not entirely convincing yet but I am on the right track. I won't post any of the other attempts until I have something that is sufficiently different or significantly pushes the idea forward.
The actual idea was to make the model convincing without too much phototrickery; adding smoke and steam violates that idea just a little but it also gives the proof that the earlier versions may, indeed, be realistic.
No problem!
D
Update on the Maunsell diesel-electric shunter: I have added a little microstrip to the top of the running board extensions and tidied up a few rough edges and joints. I also milled out a little of the insides of the body shell to get it to sit down that last half millimetre. I straightened up the odd slightly crooked handrail and retouched the paintwork. This is the result as it stands now.
I have continued with the weathering of my Hornby S15, thus ruining Hornby's beautiful pristine black finish! I have been using two colour photos in the book The Heyday of Nine Elms and its Locomotives (Colin Boocock) for reference to the degrees of weathering 'suffered' by the S15s. The first pic is of 30839 outside the 'New Shed', the other is of 30829 on a local passenger turn.
After the initial Humbrol black washes, I added a wash of their dark brown. This actually came out a bit more patchy than I wanted, but it was still a step in the right direction
I then decided that for a more even finish, I would revert to my older technique of mixing up the grunge colours and adding some matte or satin varnish. I used Humbrol 62, leather, Humbrol dark grey wash, and Humbrol satin varnish stirred very well, then added some Humbrol coal black 85. I do not mix this thoroughly, allowing the brush to pick up various shades and mixes of brown shading to dirty black. This was all thinned down with some mineral turps, before using the weathering wash the boiler and smoke deflectors, cab floor, cylinders and steps, some of the valve gear, all wheels and visible frames and pipes, the tender sides and steps, and a few other minor bits and bobs. I left the crests on the tender with a slightly thinner covering, as if they had been cleaned off in the ast but had gained a newer layer of dirt.
This has dried much more evenly, and I am much happier with the effect so far
The overall finish is just a tad too brown at the moment, so now needs a wash of dark grey shading to black to finish off the main weathering. That will be followed by a few rusty and limey streaks around the cylinders and firebox washout plugs. Then I will have to see if there are any final adjustments or additions needed to make it as near completely convincing as I can.
The eagle-eyed amongst may have spotted that I have not done anything about the slightly slanting cabside number (as all of these models have, from the factory). That may be something I'll tackle at a later stage … or maybe not!
Back in post #327, I was lamenting not being able to find the locking bars for some C=Rail containers I was building and decorating. Well, I recently placed an order with C=Rail for some of their new Freightliner containers, plus some extra locking bars to complete the previous builds.
The two 40' containers for Hanjin and OOCL are now complete, apart from possibly a bit of weathering.
The pre-finished Freightliner containers from the late '70s and through the '80s are shown here mixed in with some more modern containers. The finish on them is superb.
I still have two of the kit-built tank containers to finish off in there!
Last edit: by SRman
Approaching Christmas and the holidays, I decided to start a small tidy-up. One result of this was these two unusual wagon loads of people ready to be distributed around the layout or added to locomotives as crew. they are in suspended animation but will resume their lives once I find appropriate places for them. :)
One man has already found his way into the cab doorway on the 08 shunter!
Last edit: by SRman
Has it really been a year and a half since my last entry on the Cambrian Kits Sturgeon A? I have been putting off doing the fiddly door springs for that long. I have now fitted the springs on one side. One more side to go … then there is a second wagon to build!
After this, painting is next.
Last edit: by SRman
The actual building phase of the Sturgeon A has finished with the addition of the door springs on the other side, handbrake wheels and 'V' hangers (representing an air braked wagon). I have only fitted the outer 'V' hangers, but have not mounted the corresponding inner 'V' hangers as they would interfere with the bogie swing.
This wagon is now ready for painting. It will go into either very dirty black or very dirty departmental olive green.
looks very impresive,it will be even more so painted.
:thumbs;-):cool:
Owen
if the lights are off no cam
