track pointsin a dock scene
#290597 (In Topic #21925)
          Hi all  , need help question is ,,how do i  disguise points ,  i want to do a dock scene  ground work is going to be cobblestone using das clay but need help disguising the points hope you can help  cheers bob
Would have thought some sort of plastic sheets Bob, Noch do some but they ain't cheap.
N34224 Noch N Scale Cobblestones Place 2 Sheets 170mm x 105mm
hi  yes abit pricey but thanks for the reply
Hi,
You may consider this:
Faller 222561
A bit closer to home are the Peco (ex Wills) plastic cobblestone sheets:
Cobblestones
These sheets are invaluable for scratchbuilding, saving many hours of repetitive work creating the various surface patterns and textures. They are the same as those used in the Craftsman kits to make extension work easier. Each pack contains 4 sheets 130mm x 75mm of injection moulded styrene approximately 2mm thick, making them rigid enough to be self supporting.
View
