Decoder pro advice
(In Topic #21737)
Faulty decoder ?
Hi , I recently posted about a decoder problem with an EFE N gauge J94 loco and that problem in now resolved but I have another problem with another decoder who's I/D is unknown .I should explain the background to this to save any confusion , firstly I have very recently built a "speed profiling " track to be used for speed profiling locos in traincontroller 10 gold and decided to make it dual purpose , it is just a 1 metre straight length of track divided into 3 blocks with occupancy handled by a Lenz LRB 08 occupancy detector and this is working just fine the other intended function was to use an ESU decoder tester connected to a sprog and the tracks for use with decoder pro and this I have done .I have hit a problem though in that I tested and read the CV's on 2 decoders a Lenz and a Zimo and all went well but on the 3rd decoder I tested (an unknown one ) decoder pro gave a 309 error which it described as a short on the tracks which puzzled me as there are definately no shorts and i'd just tested 2 decoders with no problems I am wondering if anyone has experienced a 309 error and does anyone know if it can be caused by a faulty decoder ?.
If decoder Pro won't/can't even read the manufacture code, then my guess would be there's a fault in there somewhere. Does it work when installed in a loco ?
Having said all that, I have a Zimo tester and it will only work on Zimo decoders (thus far), although it can read the manufacturer codes on other makes I have................
