Silflor - Tufted Grass
(In Topic #1091)
![Avatar](https://yourmodelrailway.net//uploads/cns_avatars/2.jpg)
Silflor Tufted Grass.
It may be worth looking on wargamer sites as they do scenery and there may be other products that could well be usefull within model railways.
cheers Brian.W
I've used silflor, but up to now have only been able to get the small sheets they talk about.
It's excellent stuff, but looks even better when it's protected by the container and it's cheaper too :!:
![Avatar](https://yourmodelrailway.net//uploads/cns_avatars/113.jpg)
![](https://www.modelrailforum.com/forums/uploads/1270031106/gallery_570_3_13474.jpg)
It was used here extensively, the sheet version that is….
![](https://yourmodelrailway.net//data/external_url_proxy.php?url=http%3A%2F%2Fimages.fotopic.net%2Fymvknq.jpg)
![](https://yourmodelrailway.net//data/external_url_proxy.php?url=http%3A%2F%2Fimages.fotopic.net%2Fyn87hs.jpg)
7 years later and there has been no fading whatsoever. For a show layout, it can survive 'gerfingerferpoken' from the most active of young children and grannies.
It takes paint too, if colour adjustment is needed to create variation. It is easy to blend in with other more established materials like carpet underlay or hanging basket liner (which is basically carpet underlay already dyed green).
Neil Wood said
Although Siliflor is expensive, relative to flock, it is a far better medium. It is definitley worth paying for. The effect is unbeatable.
I suppose three sheets will cost about the same as a 4-6-0 steam loco. Think how much more these sheet of realist grass will do for your layout than another loco (of which we all have too many no doubt).
If you compare the price per square inch of both suppliers, there is very little difference in cost for the large sheets.
The advantage of "International Models" is that they have gone to the trouble of prepairing small "tester sheets" for anybody that has no experiance of the product.
That's what I've got and I'm very impressed. I think everyone who's serious about a good scenic display should try some :!:
Incidentally, it would be most useful if you could post a brief demonstration on how you've used the full sheets, Chris (Nevard), as I would imagine that the product is more versatile than my way of pulling off small clumps to make "highlights".
The base underneath is genereally first painted in some kind of earthy organic tone to avoid white baseboard, plaster, newspaper or whatever showing through. PVA/ White woodworking is ideal for sticking the Silfor down.
It was just that looking at your photos, it seemed like you had used almost full sheets and I wondered if this was the way it was intended to be used.
Scenic Express Model Landscaping Supplies
the results are great but at 149 dollars or from the UK at 117 quid :shock: :shock: :shock: i have seen the puffer bottles but i have heard these are not so good. i suppose if your layout is quite large with a double track running through sweeping fields and lots of scenery then spending the money may be worth it. :D when i get in the new house i want a layout with double track running through sweeping fields and lots of scenery mmmmmmmmmmmm. maybe i should budget for one when i price up the shed :D and if you are going for the tuffs it is only ten sheets and you have your applicator, you could then produce tuffs and flog them on fleebay 8) 8) 8)
if buying these tuffs would the 2mm scale look better with 00? like 2mm scatter ballast looks better :wink:
Lawrence, I think that the 2mm size (shortest) could well be OK for N gauge. I'd buy a sample size sheet from International Models and try it out, if I were in your position.
Gwent Rail said
Thanks for the clarification, Chris.
You're right, I do use full sheets, I just break them up when covering a large area, for some reason it looks better sticking it down in smallish segments like a mosiac. Inspiration as to how it should look? The real world works for me :)
Combwich my 10'6" x 2'3" layout used 2 sheets, £35 or so well spent I hope? Once you've used this stuff, Woodland Scenics turf will never get a look in again. Grass is fibrous, not scale bath sponge sized lumps of bright green foam 8) Sorry, I get rather passionate about scenery…LOL!
I sometimes think I'm a bit like the "odd man out" when I pass a layout with lots of trains running and no scenery, to spend 30 - 40 minutes in front of a layout like Combwich.
I sometimes wonder "if locos suddenly stopped working forever, would it affect my enjoyment of the hobby" :?:
The answer is "less than 99.9% of all modellers I know". :wink: :roll: :roll:
![Avatar](https://yourmodelrailway.net//uploads/cns_avatars/19.jpg)
I am soooo looking forward to getting to the stage where I can work on scenery rather than roadbed, track and electrics…
I'm still having a lot of fun but it is such a sloooowww process.
The Silfor and MikeC's dusting cloths look well worth spending some experimenting time on.
![](https://i80.photobucket.com/albums/j177/neil_s_wood/IMG_2960.jpg)
This is pure moorland. One sheet
![](https://i80.photobucket.com/albums/j177/neil_s_wood/IMG_2950.jpg)
This is long pasture again one sheet
![](https://i80.photobucket.com/albums/j177/neil_s_wood/IMG_2854.jpg)
Its a fairly extensive range and covers many types of grass and moor. Its worth getting a couple of the samples to see exactly how good it is.
