Model Railway Structures
3D Printed Items
Each of my products is scientifically tested prior to being released to the market.
Actually I was quite surprised how strong it is. I will probably remodel this when I find someone who wants a 21st century train shed roof. This first print was really just an experiment.
Here it is sitting on my keyboard so that you can get some idea of its scale / size.
As you can see, you can definitely make out bricks.
Here it is balanced on the ridge of a Metcalfe corner shop I made (very badly) a few years ago, which gives you some idea of the size. Now that I know that it works I will knock up a few variations and some larger ones (when I get time).
I've also released it on Shapeways at 7mm to the foot scale.
Bob
The prototype is under production at Shapeways and should be with me first week in April. However, the material it is printed in is strong and not at all brittle. I would expect it to be throw across the room tough. When I get my hands on the first print I'll give it the throw across the room test.
I would recommend painting the components before assembly and then touching up as necessary afterwards. This was fully assembled prior to painting and it was a bit of a fiddle.
I have now created some bulk packs on Shapeways, which improves the cost per item. Anyone contemplating creating lots of canopy PM me and I will see if we can tailor the bulk packs to suit your needs.
Last edit: by Wizmacnz
Is it strong ? I'm wondering how you've fixed the columns to the platform surface …….there's quite a lot of "top hamper" for a single lateral support :hmm
I'll have a look at Shapeways and see what your bulk discount looks like ……………….:roll::roll::roll:
The columns have a 1mm plastic pin below the base that I pushed into a hole that made in the platform with an awl.
I haven't glued it in yet and it has become a bit wobbly with me taking it in and out so that I could paint it. I think it will be pretty strong though when glued to a platform.
The plastic itself is a form of Nylon and not brittle so it will take a few knocks and a bit of rough handling.
It's actually printed in Holland. The postage and packing is a flat US$9.50 rate per order regardless of whether you buy a truck load or a match stick. I have to pay $US19.50 per order to have it delivered to New Zealand, but I have to say delivery is fast, track and traced so I know exactly where it is at any time and very well packed in little cardboard boxes with lots of bubble wrap and those plastic bag things full of air.
Keep designing especially furniture as I detail the inside of all my buildings do the table and sofas is on my list to order!
I will build up a order list before I order then the more the cheaper!
I thought it was only me that was interested in the furniture. It was one of the first things that I made to place inside a building on my layout. I was planning on some kitchen stuff next in that line.
[user=981]jimmy styles[/user] wrote:I will build up a order list before I order then the more the cheaper!
Sounds like a good idea. Have you thought about, fireplaces and possibility a grandfather clock bet they would look great with this level of detail.
Here is the first rough of a fireplace. I need to model the whole chimney breast if I create something close to realistic depth in the grate.
I think the grandfather clock idea will have to wait for higher resolution printers. I could model the shape of the clock leaving it for someone to paint on the detail, but then Scalescenes do a clock that is rectangular, but would probably look better than a hand painted printed clock.
Does anyone have a copy of that sheet so I could know what diameter the clock faces are?
This is in the shop in one size only at present. 900 wide x 1200 high (approx 12 x 16mm). But I can make them any size you want. It's a parametric model so it's just a two minute job to type in the size required and upload it to Shapeways. If anyone is interested and wants any particular sizes just let me know.
This item really benefits from Shapeways bulk discounting. 1 off is US$2.75, bulk pack of 10 is US$6.00. Actually I think its more that single small items are penalised by the systems pricing structure.
