Windows 10 problems?
(In Topic #11995)
You are not alone
Don't use it, but may be of interest.http://www.bbc.co.uk/news/technology-37431343
:thumbs;-):cool:
Owen
if the lights are off no cam
It took a bit to install Xubuntu 15 but it did retrieve my valuable files and computer but I have had stability with Linux that MS only promised but never delivered for me… I would be hard pressed to trust that company with anything ever again… plus the price is right on Linux software in general means there is little or no turning back and the learning curve was not a great one by any stretch…
So Owen if you feel you might like to change… do it!!
Regards from Melbourne
:thumbs;-):cool:
Owen
Been using it since July :thumbs
Here's a test pic.
Allan.
CheersRon
It can be downloaded from here Alan, and I expect you'll want the 64bit versionHow easy is it to install Xubuntu Ed? and can you set up a duel boot?.
http://xubuntu.org/getxubuntu/
You'll need a CD/DVD drive to burn the downloaded file onto a CD
When booting the CD to do the install, it gives the option to install alongside any current O/S or wipe the PCs disk.
Just install alongside Windows 10 and when it's all done you'll get a boot menu each time you switch on.
xubuntu-16.04-desktop-amd64.iso
dated 2016-07-19 22:10 1.2G
from near the bottom of the list.
Last edit: by Ed
See my last post for the file to download.
Once it's downloaded you can burn the file to a CD with whatever software Windows currently uses for doing that.
The OKIs print on card up to 200+gsm, and banner paper up to 1200mm long (which is great for backscenes).
When any new bit of kit comes out you have to wait for someone to write a piece of driver software for it, although HP were/are pretty good at supplying drivers through Linux Imaging and Printing software (HPLIP).
On the other hand it's open source and there are no 'fat cats' sitting back making mega-bucks out of users.
Last edit: by Ed
Computers are like any other product today. We expect more and more of them, but aren't prepared to outlay the dollars to keep our equipment up to date.
Forums are part of some modellers' paradigms. They need to be kept up to date as well. This forum has out of date codes to run the Gallery. It works fine with off site photo hosting, but a range of browsers are becoming incompatible with the old code with runs the Gallery.
Windows 10 is pointing up this disparity.
Raging against the machine will achieve nothing.
