The Serif Learning Thread
or.....Matthew 15:14
Hi Les,This is where I got the figure from
[a brick]……….. I am going to take as 3.25" high including mortar, so that makes each one 31 bricks or 100.75" " or 8.4ft and at 4mm/ft equals 33.6mm high. Remember this figure! We don't need to know the width because Serif will re-prportion the pictures accordingly………..
Mine are 3.3 x 4.2 cm.
Les
Devon Junction
Kernow Junction
Kernow Junction
31 x 23
thud
thud
thud:thudI'm going to lie down.
Les
Devon Junction
Kernow Junction
Kernow Junction
Pretty good first go, my signs are 44mm x 33mm.
Here's a print out on ordinary paper as a test:-
So far, so good quest:quest:
Right. Went back to basics and got the source photos again. Then fired up serif and brought them across. Diligently re-sized them with 3.36 in each height box after changing to centimeters (this gave a width of circa 4.48) and changed the quality from 200 to 300. Did the copying and pasting etc and then printed on equiv of photo paper with white background, at 300 dpi on 6 x 4 paper. I now have four beautiful little pcture each of which measures:
31 x 23thud
thud
thud:thud
Les
I'm going back to find "each height box" as I thought there was only one….
Buenos noches.
Les
Devon Junction
Kernow Junction
Kernow Junction
Hasta mañana, duerme bien mi amigo.
Further thought, check you are printing on 15cm x 10 cm paper and you have the fit to paper/stretch to fit/exact size set correctly.
I'd have thought that the size of paper used was irrelevant as long as you had the size of each print / wall scaled correctly quest:
I used an ordinary A4 sheet for my test (as shown above) which is 21.2cm x 29.5cm and the only effect was in having extra blank paper on the sheet.
When i close the programe it save's them to a file i created and when i bring them back i have to resize each time for some reason but thats ok as i then know they are correct.
Phill, get your sheet of 4 signs, correctly sized, on the grey screen in Serif (as per Doug's instructions).
Next use the "file" drop down menu at the top left of your computer screen and from the list select "save" or "save as" and click. Follow through as normal for saving an item.
The image will then be saved to the folder you create in the correct size for re-printing.
Ps this is for our teacher
Last edit: by phill
I'll have to catch up at a later date. I've b*ggered my back up again stacking logs, so will be laid up for a few days…:sad:
Supose i just wait then, :thud
[user=312]dooferdog[/user] wrote:Further thought, check you are printing on 15cm x 10 cm paper and you have the fit to paper/stretch to fit/exact size set correctly.
Jeff, if you have A4 or A5 set on your printer options and print with 'Stretch to paper', 'Fit page' or 'Custom' instead of 'Exact size' it will print accordingly…..You clearly have the right size selected.
Sorry he's not been to school, he's been a very naughty boy, and hasn't finished everything else he has to do first, such as put up the tree, the lights, the streamers, cook the meals… If he's allowed on the computer at home he may be allowed to take the lesson.
[user=3]Gwent Rail[/user] wrote:I'd have thought that the size of paper used was irrelevant as long as you had the size of each print / wall scaled correctly quest:
Clearly exclam:
Now, to be a "smart ar**se", I tried an experiment of my own. A few images on file and some size trials produced:-
Actual printed out sizes of the Rajah ad. are 21mm x 37mm; 20mm x 34mm and 14mm x 24mm. Bovril ad. sizes are 13 x 34; 11 x 29 and 4 x 9
Suitably emboldened, I imported Perry's 3 bay warehouse into Serif and added my own sign, thus:-
Teacher will either give me a Koala stamp for initiative, or a swift kick in the goolies for getting ahead of myself exclam:exclam:
PS on edit: The only thing I can't work out is why the Serif page is neatly arranged starting with images in the top left corner and working down the page, my efforts print out centrally located on the A4 page. I guess it must be something to do with printer / page settings quest:quest:
:Red Card:Red Card I wasn't the one that gave teacher an apple exclam:exclam: :lol::lol::lol:You always get someone in class being a creep and i guess we found one :twisted:
