Possible forum 'standard' free image/photo programme-Photofiltre
(In Topic #5316)
Please evaluate if you would like to
I have been searching for some time for a free image/photo programme that we could adopt as a forum standard, so that we can swap info/methods/files for jobs like cutting, pasting, downloading and manipulating graphics without spending a fortune on a commercial product.I have found this one
http://www.snapfiles.com/downloads/photofiltre/dlphotofiltre.html
and have used it to do all the things I need to do to produce examples of downloaded, resized and cut-and-paste images for back-scenes and modelling. It opens to a zip file.
I have 'Norton' checked it and it runs through Iobit spy-ware without any problems, so I ask if all those who are familiar with like products to have a try-out, if it is deemed suitable I shall suggest to Senor Bob that we adopt it.
It is reasonably intuitive to Photodraw/Photoshop users and there is a help site with tutorials.
I think the Photoshop software was about £1,400 so I'm quite pleased it's not redundant!
I have downloaded the program and tried it Doug and it seems as good as any other, and a freebie of course. Makes sense to me if we are all talking about the same piece of software.
Hullo, Bob, thanks for your try-out. I have been trying to select a window, copy it and paste to a new document and then get it to print out consistently to the correct, i.e. demanded size with little success. I've wasted most of the day trying and re-trying, I got it to work once but not since. I shall have another try and see what happens.
Frustrated Doofer.
I have Faststone and love it, it can
1. download a picture of a building, like an office block
2. crop and save to file an element such as a window
3. allow a succinct re-size of that window to fit a scale model
4. allow it to be printed out
BUT
unless I am being very thick you can't put several of that window on 'one piece of paper' together with other slightly different windows or other element and print them all out at once.
I have even tried its facility to compile a PDF contact sheet but that is a sledgehammer and nut scenario.
I have tried saving the same window as 4 different jpegs but, again, whilst you can print multiple pictures they will each be on separate pieces of paper.
You could open a Word for Windows file, insert several text boxes and paste in the same picture into each box, only if you have a full Word for Windows, I don't think the Word with MS Office will cope with it.
I'm off back to the drawing board!
I don't know anything about faststone but I've just tried copying the same picture into a number of text boxes in word (Office 2008 for Mac) and it works fine.
I'm happy using my MS Photodraw programme, but I'm trying to find a way to help people like Peter Mac without them spending £90 on a programme they may hardly ever use.
printed and measured and prints to correct size. click on text box and copy and then paste as many as you like. Job done
Last edit: by pnwood
a. Something like Faststone to do the cropping [true, a good freebie]
b. At least MS Office Word
I wonder if the slightly Pooter-phobic amongst us will do it?
I like the idea of Faststone to capture bits of downloads because you can set gamma correction 'live' and use the compare pictures function to see, for instance if all your various disparate elements are of about the same brightness.
HHhhm. I'll have another look at some of the other freebies, thanks, Dave for the Gimp reminder, I have that too, but it's a bit of a toughy [at least for me, I found it worse than Corel Draw to pick up.
Time for a little SLW to wind down with, I think.
I've used it to make background buildings. It will layer as much as you want. I did find it a bit tough to learn, and I have to say I've already forgotten how to operate it :lol:
It was a free download too.
I have downloaded it and had a 5 minute play…….. [haven't you anything better to do than play with that computer…you still haven't finished clearing up the tomato bed, and there is wood to stack up, and……]
It already looks better than the others. I was a little reluctant to try it as it requires registering, promises to send you bumf etc, but during the installation there is a chance not to install toolbars for 'Ask' etc.
I'll get back to you later when I have done some of my chores!
[In 5 minutes I've managed to open a downloaded building, select and copy a window frame and save it ready to use elsewhere, hopefully]
I am hoping to model Exeter St Davids station and this is a shot of the gable end of the main station building. If you look at the first floor you will see two arched contraptions - they are actually not windows because they were boarded up behind them but they actually look like window frames. The front elevation has no fewer than 64 of these and with the two end ones 68. My model will have to be smaller but will still involve 44 of these window type shapes side by side. Is somebody saying therefore that with some of this software I could take the photo above, scale it down to 4mm/ft and then print it out with all 44 adjacent to each other to provide me with a template from which to work?:???:
Les
Devon Junction
Kernow Junction
Kernow Junction
Like this, Les? I think one of our real eggspurts could do this in a format that York models could cut from 10 thou plasticard as an overlay…?
