Metcalfe Low Relief Shops
(In Topic #1207)
They really are quite good kits with easy to follow instructions and well cut parts.
The first is here (my partner Liz, loves the "chippie" although Jeff beat me to it !!):
Eventually, there will be a row of 8 shops with adjoining houses - all in stone.
You'll see that, on the left hand shop, I got the upstairs windows the wrong way round so the top sash is open. :oops: :oops:
I will need to weather them slightly to tone them down. The setting is a Pennine mill town - not sure yet if it's going to be animal feed or wool/cotton but whatever, they'll need at least slight weathering if not the black soot type.
Advice/critical appraisal would be greatly appreciated (and I DO mean that - I want to learn from others !!)
Also, advice on weathering would be great.
Petermac
Be careful if you weather them with paint. It'll need to be very dry. Chalks work well though. Maybe a bit of faint grey-brown down low, splashed up from the paving, and perhaps some green on an end wall where it's less sunny…?
phill said
They look ok and as for the window, as i recall my aunt had sach windows and hers opened top or bottom, so it is ok.
You're right Phill - we had them in UK and both sashes opened - I just wanted to have someone leaning out - maybe a giant !! I had to put it upside down because the fancy moulding on the bottom of the sash is correct - it's just that I got the wrong side facing outwards !!
Petermac
MikeC said
Looks very good :!: A long row should look pretty impressive. I hope we get to see it when it's done :) A pity about the window, but if you hadn't mentioned it I wouldn't have noticed.
Thanks for that Mike. I was worried that paint might delaminate or stain the card. When you say "chalks", you obviously mean artists pastels but do you mean just ground chalk put on with a brush ? How does it stay put ? Would I not need to coat it afterwards to make it stick ?
Petermac
Brian(G)
I realised I'd got the windows the wrong way up Diesel when I fitted them. I fitted them with the moulding correctly at the bottom of the sash, but then realised the top sash was open. I checked the other windows on the acetate carefully and found I'd put those two in shiny side out !! The other half block will have the bottom sash open - at least it'll be different !!! :? :?
Petermac
Very senior moment I'm afraid computer siezed and I kept clicking "submit" - please someone - how do I delete the duplicates ?
Petermac
The section moderator normally but as there is no official moderator for this section the honour falls on Bob
cheers Brian.W
Petermac
They are in the right way round (painted sash to the outside) and I've cut out the top window for it to be "open".
This is the correct way, as the top part of the window was the one left open most often (although both parts would open as Phill says).
How do I know, you ask :?:
Well, as a valley boy, we had sash winows on our house. I used to open the bottom part and hang out, but my mother would always shout at me and say it was dangerous.
"Open the top, you can't fall out from that" she would say.
Petermac
Robert said
Top right of each post there are four little icons for Quote, Edit, Delete and IP. The Delete is just a little X.
I'd clicked on that button Bob thinking it was either/or. I didn't notice the button was split so was obviously clicking the "edit" bit. All together now "Come on Petermac !! Wake up !!" :oops: :oops: :oops:
Petermac
