Metcalfe Chimneys
(In Topic #8664)
I have terrible trouble doing the Metcalfe chimneys, has anyone got any shortcuts or tips for doing them.
Thank you
Charles Wilson
Sydney Australia
Charles Wilson
Sydney Australia
Sydney Australia
http://www.forty-third.co.uk/76_sdm_buildings.htm (Obsolete link and couldn't find a replacement but the following posts are still useful - Barchester)
Last edit: by Barchester
Rhiwderin_Ray
Rhiwderin_Ray
Dart casting have some quite nice whitemetal chimney pots - their pack has an assortment of styles.
I doubt you will find many (if any) whitemetal chimney stacks for sale.
Stacks are available, although not necessarily whitemetal. These are plastic, along with some white metal pots;
Z
If you have a look through his card modelling topics, I'm sure you'll find it. :thumbs
Woteesed!… and if you want some fluting on it wind thin strips of self adhesive labels around (cut with a sharp scalpel) before painting.Take a biro tube (the ink bit not the outer pen) and cut off a section to length. Stick a cocktail stick into the end to spray with car primer and then paint with acrylic. Glue in placeSimples!
How did you find it ?
Charles Wilson
Sydney Australia
Charles Wilson
Sydney Australia
Sydney Australia
In our Index under C for Chimneys - where else quest:Thanks Sol - exactly the thread I was looking for. :cheers
I was looking through Doug's threads - didn't realise it had been indexed ………………:sad:
Bob
As a street tramway modeler with tenements to model chimney pots are the bane of my life, providing I NEVER even think about individually laying cobbles,:shock::shock::shock: since a single stand alone tenement has up to 42 pots IF you ONLY go to 4 storeys.
I use any small diameter tube I can find. Biro tube, lollipop sticks (plastic are best as they are hollow), spaghetti (moisten it first to avoid shattering), also good for drainpipes. 4mm gas welding rod is good but you need a plumbers tube cutter and a prize beyond rubies was a quantity of small bore pneumatic tube nipples. The tube iself is good but as it tends to come in rolls straightening it out can be tricky.
Invest in a rotary hole punch which has a selection of sizes and you can punch out a holder to get better adhesion.
I dislike rolled tube pots as there is always a line where the joint is and I am willing to bet that a quick look around most layouts will show the dreaded line down at least one pot which slipped through the inspection process. Even whitemetal or resin pots need to checked for mould lines.
Just my take on this situation and it's also a snag you need to look for when you want to use round columns for station canopies.
Jim
Model Railway Structures by Wizmacnz - Shapeways Shops
I'm always prepared to add to the range if someone has a specific requirement.
