Low Relief Brick Terraced Houses
:doublethumb;-):lol::lol::lol::lol::cool:
Well done mate
Put's mine to total shame. :oops::oops: When I'd "finished" mine - "out of the box" - but in stone, the first thing that sprang to mind was a comment I'd heard before somewhere - "Could do better" !!!!:roll::roll::roll::roll::sad::sad:
Most impressive. Can I ask what you used to stain the wooden beams as they give a great impression of weathered timber?
Sorry so long in replying, been away for a while…….
Thank you for your kind remarks:oops::oops:
The wood is thin softwood, planed smooth, then sanded lightly in different directions with medium glass paper, a coat of 'gunge' coloured acrylic wiped off after a couple of minutes and allowed to dry, and then either painted with dilute dirty black for the battening on the walls, or, for the supports weathered with a dry brush application of watercolour.
The fence is my own print-out on 140 gm 'NOT' watercolour paper, which gives a minute texture to the surface.
Cheers,John.B.
thud:thudIf you had built them out of Plastikard in the first place they wouldn't have needed shoring up! :lol::lol::lol::lol::lol::pedal
Seriously, I'm not a great fan of card, but I have to admit that these really do look terrific. Well done indeed.
Perry
:lol::lol::lol::lol::lol::lol:Oh dear! Had to prop them up, did you?thud:thud
Gawd knows I've tried hard enough to get'em away from that horrible, nasty plastic stuff. They just wont listen. :It's a no no
That does not mean, I assure you most earnestly, that I do not respect the skill they use in making the models.
I just like knowing that my model is my model, from the ground up, for instance, in the roof below, I wanted the effect of the rough ended old slates, so cut the strips off in some places, to include the drawn line for the slate below, to give that effect.
Some one else may do the same, but not exactly like mine. I'm not ranting, but give an OO model a look-see from a reasonably scale distance, and brick pointing would be invisible, some need to see it, because they know it is there, so want to see it.
Below is a real slate roof, [modern machine cut] , at 20 ft away you would be hard pressed to see the thickness of a slate, let alone a scale 200 yards….
As for the often quoted 'lack of texture' of card and paper models, I don't think this lacks scale texture, do you? A little 'broken' ridge tile detail, the ridge tiles not pressed too hard down so as to leave hollows and so on, all add to the sense of texture. (IMHO) I cant find realistic ridge tiles, not even in the excellent Scalescenes range, so do my own on the 'pooter from matt photo paper, and 'crease them with a blunt scalpel blade after the glue is dry.
Please be assured I do not want to start a 'mine's bigger than your's is' thread, I'm just explaining why I model in card, and really would like to see some of the skilled plastic modellers have a go in the medium,
modelling books etc, all hand made their models from whatever they had,
mostly card or balsa, i have books full of terrific buildings made this way.
:thumbs:thumbs;-):lol::lol::lol::lol::lol::cool:
Well,Dooferdog,you've convinced me.I'm going to try to stick to building in card and paper wherever possible!
Cheers,John.B.
Cheers,John.B.
One of my Ahearn books has a page dedicated to how to make a razor blade holder, and how to sharpen a blunt razor blade. Even with all the modern materials, tools, facilities, not to mention lighting available, I can't touch those two who were after all writing modelling books as wellas doing the day job!
Not all the old ideas have been bettered, I recently made the hipped roof above using brown sticky parcel tape on the inside, and shall never use glue again, it went together so squarely and cleanly, and had I made more than my usual cock-up of it, a 'razor blade' down the join would have separated the parts in seconds without damage, too.
Ah, well, each to his own, one of the best things about this hobby is that there is no 'right' way, look at the superb work shown on this forum, all done in subtly different ways.:thumbs
