My Scratchbuilt Catenary
OO gauge OLE
Big improvement Ed,looks just about right to me ,,:thumbs;-):cool:
Owen
web-cam 2.2.74.174:8081
if the lights are off no cam
Looks very nice (whichever version). One thing about catenary wiring is that it zig-zags from side to side to keep the wear on the pick-up bar even. Nothing obvious, but it's there. Easier to do with version 2 I would imagine.
Try K&S PB wire, 10 or 15 thou' diameter, comes straight, about 8" long and is very robust.
Thanks for the suggestion about K&S PB wire Nigel.
Many people appear to use guitar strings or piano wire, but I'm trying to keep costs as low as possible and use readily available 'standard' materials.
Moving on to masts, for some reason everyone seems to have run out of stock of 4mm square styrene tube. I've some on order, but may have to wait a couple of weeks.
Meanwhile I'll make a couple of new posts using the 5mm tube I've already got.
Slight design change for the arms and going to use 0.8mm wire (stripped 1mm2 twin and earth) to again make things a little less 'chunky'.
Think this is going to end up a design cross between BR Mk1, BR Mk3 and LNER Shenfield line 1500Vdc
Talking of which, I found this old film. Haven't watched it all yet, but interesting bit between 10:30 and 11:30
http://www.eafa.org.uk/catalogue/764
'elf and safety, what's that!
What always strikes me about these old films is how hard we (they) worked in those days, how dedicated they were and how "proud" everyone was of their achievements. Nowadays, everything is done by machinery in half the time and nobody gives a damn.
The result seems to be that most people are short of cash, most don't have any spare time many thousands of people are unemployed…………:???::???::???:
I wonder where we went so badly wrong ………………….:hmm
I'm happy being a Luddite ………………..:cheers
That cantenary is looking really good.:thumbs:thumbs:thumbs:thumbs
I reckon once you paint the wires it won`t look chunky. I found that when I painted the staples on my tension lock couplers they practically disappeared.
Another thing….don`t know if it`s of any use to you, but if you lay a length of wire on a flat, hard surface and then lay a length of timber over the top of the wire and roll the wire under pressure and sandwiched between the timber and the hard surface…….it will help straighten the wire.
:cheers Gormo
I've read that if you paint the wires black they look thinner. Someone made the analogy with women and little black dresses, but I couldn't possibly comment.
To straighten and harden the wires I put one end in a vice and the other end in the drill chuck. Pull and turn slowly for a few revolutions and et voilà .
Works for 1mm2 and 2mm2 twin and earth and 1/0.6 equipment wire, unfortunately didn't work on the 0.4mm copper and brass jewellery wire.
:thumbs;-):cool:
Owen
That'll do.
Working on portals for the station and an anchor mast for the end of the line now.
I'm still a bit undecided about height though.
According to Hornby, their old system should have the contact wire 73mm above the running rails and the UK Model Shops article by Alastair Thompson says 76mm above rail tops.
Prototypically, BR Mk1 catenary had the contact wire 16' 6" above the running rails (66mm) and some people on RMWeb quote 64mm.
:hmm
Think a lot depends on whether the catenary is being used for power pick-up, which in my case it isn't.
Bearing in mind I doubt my track is that level, and I want the pantographs fixed a couple of millimetres below and not touching the wire, think I'm aiming at roughly 68mm for the catenary contact wire and fixing the pantographs at 65mm.
Of course, that could all change
Pete.
Done drawing for the portals to carry the catenary through the station area, just got to build it.
Also found another shorter old film about the electrification of the Southend line.
http://www.eafa.org.uk/catalogue/766
(The music in these early post war films really dates them
keep it coming.
:thumbs;-):cool:
Owen
:lol::lol::lol:Ed
Superb drawing work too and as to accurate hole drilling, don't worry, just take a note from Eric Morcambe's book when piano playing for Andrew Preview: all the right holes have been drilled, just not necessarily in the right places! (only joking!)
https://www.youtube.com/watch?v=r7yb-JncKow
Looking forward to the next report. Bon courage as we say in these parts,
Bill :)
You`re making good progress there and those cantenary look really good.
Your forward thinking with the height possibles makes a lot of sense. All you can do is try what you think will work and test it thoroughly. Then you`ll know for sure what works.!!! There is bound to be some variation in height somewhere……..Murphy`s Law….so you may have to make some adjustments, but at the end of the day, slight adjustments will not be obvious to the visitor, they will only be obvious to you. I would think rise and or fall of track between two masts would be your biggest hurdle, so compromise may have to kick in there somewhere.???
Gormo
That link doesn't work, might be a licensing issue in the UK, but I know the clip you mean.
As for "all the right holes have been drilled, just not necessarily in the right places", I've been saying that since I started the layout two years ago
Doing this has made me realise how glad I am that I'm not trying to model a four platform terminus station.
All credit to the blokes that do though, the amount of masts, portals, head spans and 'knitting' would be far beyond me.
